Hot Rod Forum : Hotrodders Bulletin Board - View Single Post - clutch slave cyl vs hydraulic throwout brg
Old 01-24-2005, 04:14 PM
M&M CUSTOM's Avatar
M&M CUSTOM M&M CUSTOM is offline
Wiki Edits: 9
You could also use a small hydraulic cylinder with clevis pin ends for a custom set-up.
I have also seen rock crawler clutches operated with use of motorcycle chain and sprockets.
