clutch slave cylinder mount - Hot Rod Forum : Hotrodders Bulletin Board
Old 03-02-2002, 10:13 AM
Talking clutch slave cylinder mount
have '37 Ford with chevy powertrain 4-speed.. have viper hanging pedals. Problem is I cannot locate or observe a design for the hydraulic slave cylinder for the clutch. I desire a mount of sorts on the bell housing and GM tx so the unit can 'push' toward rear of car. There is lack of mounting bolts available and I wonder what will work any help out there?
I have it already in car so am not enthused about removing tranny etc. for bell housing change, there really should be some kind of mounting bracket 'I think'
[ March 03, 2002: Message edited by: wally ]</p>
Old 03-04-2002, 10:20 AM
Cool
Just a thought . Is the reason you cant find the mount for what you beleive should be a slave cylinder because they installed a hydraulic release bearing? This is another method of using a hydraulic clutch set up. Look for fittings or lines that come from the release bearing. I take it you are maybe assembling a kit car?
Hope i was of some help!
good luck!
