Clutch suggestion - Hot Rod Forum : Hotrodders Bulletin Board
Old 02-28-2006, 12:00 PM
Clutch suggestion
Hello all, new to this bulletin board. This is what I got. I have a 1958 Biscayne. Frame on restored with a GM crate HO350 330 HP Delux. Also running a 9" big bearing Ford with custom axles and 3:73 posi gears. Now I am removing the TH350 trans for a wide ratio Muncie M-21 4 speed. Already got the new Hurst Comp shifter and linkage kit for a M21. Ok the question I got is what is the best route as far as a new clutch. Hayes, Centerforce, McLoed stock? This is a 10 spline 11" clutch. What is everyones preferences and why?
Thanks for the help
Old 02-28-2006, 07:07 PM
broncoII88's Avatar
Do the right thing...
Centerforce clutches are remanufactured and need a 400 to 500 mile break in period.
Hayes is a good brand. All new compnents that come in complete kits. I have a Hayes super brute clutch in my Bronco II and it's great! The pedal is a little bit stiffer, but I don't mind it. Haye's also makes a wide range of flywheels too.
Ram makes clutches for OE replacement as well as racing applications. I don't know much about them though.
Hope this helps a little bit.
Clutch problems on 66 Mercury onebadmerc Transmission - Rearend 21 09-23-2005 03:21 PM
Clutch preload? RB401 Transmission - Rearend 0 08-03-2005 09:26 PM
Lakewood Clutch fork clip broke/angle of clutch fork 70bird Transmission - Rearend 3 04-23-2004 07:04 PM
Suggestion for clutch. Shefron Transmission - Rearend 1 05-12-2003 09:33 PM
clutch linkage!!? chevyelc81 Transmission - Rearend 11 08-01-2002 06:46 AM
