Clutch/Throw-out bearing in 2002 F-Body - Hot Rod Forum : Hotrodders Bulletin Board
Old 08-26-2003, 05:53 PM
I have a 2002 Firebird V6, with the manual 5 speed transmission, and have always had noise coming from the throw-out bearing. I had the dealer replace it under warranty, but it still seems to make a lot of noise like it's dry....My question is this...
Is the throw-out bearing, and the slave cylinder on the clutch housing sort of integrated, or is the cylinder outside and away from the bearing....the reason I ask, is that the slave is now leaking, and everytime I push the pedal it's sucking in air, and now will not go into gear....The dealer is going to charge $675 to fix the leak, and I was wondering if there was any other explaination, like did they replace the bearing and cause the leak?
Thanks!
Old 08-26-2003, 08:41 PM
johnsongrass1's Avatar
Race it, Don't rice it!
I think, but not positive, the slave is inside the bellhousing, bolted to the front of the transmission. same place a pump would be in a automatic. That's where you high prices are coming from. they have to completely remove the trans to change it. I don't see how replacing the bearing would cause it to leak. Other than a really crappy job to say the least. If it hasn't been to long than complain and see if they will bargian with you for a lower price on the replacment. In fact if you really think they are to blame then throw a coniption fit and see what happen's. Either way it should'nt be leaking at all. If fluid were to get on the clutch plate then it may cause a very annoying chatter as well. It shouldn't make any noise either.
Old 08-26-2003, 09:11 PM
I actually did sort of a "coniption" by email to the GM corporate...They called back in a couple of hours. I told them that I have bought 8 GM cars, and this is the 3rd Firebird, and the clutch was fixed two times before this....all under warranty, and now RIGH AFTER the warranty is up, the slave goes.....hmmmmm
The slave shouldn't be a part that I have to replace regularly, and I am very easy on clutches....
I'm hoping that this will encourage the dealership's service department to give me a break....
Thanks for the info though!
Old 08-26-2003, 09:41 PM
axle bastard's Avatar
you're killin me buck!
dunno about v6 f bodies, but the v8 slave and throw out brg. are one unit.
Old 08-26-2003, 11:33 PM
So if I were to complain about a less than stllar t/o bearing replacement causing the slave issue, I wouldn't be too far off? I really wish I wasn't in such a bind right now, or I would ahve done the replacement myself along with a higher performance clutch...
If anyone knows for sure if the t/o and slave are the same or close, let me know...even if it is just for the curiosity.
Old 08-27-2003, 06:36 PM
Clutch/Brake suggestions?
OK...I got the "official" word from the maintenance person working on my car that the t/o bearing and the slave cylinder are one in the same unit. If they replace the bearing, they are also replacing the slave. I guess that means I have ammo to negotiate with....
On another subject, I'm thinking of putting a "performance" clutch in it, and was wondering what else I should get to go along with it? Shift kit? New drive shaft? New gears?
Also, I'm going to replace the stock brakes with a vented rotor and better calipers...any suggestions there?
