(Clutch or Tranny problem) Shake & Rattle 79'z28 w/SuperT10 ! (Video) - Page 2 - Hot Rod Forum : Hotrodders Bulletin Board
  #16 (permalink)
Old 07-24-2011, 04:20 PM
spinn's Avatar
The bellhousing pins align the input shaft of the pilot to the crank pit. the bellhousing angle alignment is as important as the differential angle.The oil leak could be rear main seal if bell deflection is twisting the main against the shaft.
  #17 (permalink)
Old 07-24-2011, 07:38 PM
thats pretty violent
i watched that video i also agree with nova ss you got to pull that diff cover something is not right in there bty 79 camaros had a issue with spider gears mine weleded them selves to the shaft then blew apart could not even be rebiult
had to ge another rear
  #18 (permalink)
Old 07-24-2011, 08:29 PM
RippinRon's Avatar
From what I've read other people have had similar problems with their zoom clutch.
  #19 (permalink)
Old 07-27-2011, 11:07 AM
wow,i would love to read that, did a search and i couldn't find a thing
any links ??? thanks !
This only happens when you clutch and the sound is aroun the bellhousing area , is that possible ?
  #20 (permalink)
Old 09-21-2011, 06:01 PM
The mistery still continues !
Still shakes like http://www.youtube.com/watch?v=kIwRtHHxp08
Hi there, we still have the problem ,we replaced pressure plate two times
and tried another clutch disc, that's not the problem.
We thought now five possibilities possibilities :
- Pressure plates (pic 1 and 2) incorrect seating ???
- Back side of the flywheel out of shape ? (bottom right picture) a guy told us this possibility but i dont think so at all ....
- Worn Flywheel ( i don't think so )
- Play on the shaft w/t-bearing (not sure if its normal) it has less play on the back side of it (video below)
- Play on linkage making the cluch apply with more power on a side (video)
Here is the new video : http://www.youtube.com/watch?v=G0HhHrKoPjs
thanks !
  #21 (permalink)
Old 09-21-2011, 07:08 PM
I did solve my clutch chatter, and it turned out to be a bad slave cylinder.
Yes, at first it didn't make sense. Usually, a leaking slave will just cause clutch fade and you have to pump it to get it to work.
Best I can think, is the leaking Slave Cylinder allowed air into the hydraulic system, and the air acts like a spring, amplifying small un-noticeable normal chatter into a big issue.
Swapped the slave cylinder, bled the system, and all is now well.
Not sure if any of my experience applies to you, but thought I'd tell you what I found.
PS: Another issue is watch where your clutch fork ends up. Sometimes they can catch on the tunnel or other parts as they don't always move exactly where you think they will. This can occur during high torque, like when being in 1st gear, but not so much in higher gears. Fork bounces, and clutch chatters.
  #22 (permalink)
Old 09-22-2011, 06:32 AM
we don't have a slave cylinder
  #23 (permalink)
Old 09-22-2011, 12:44 PM
u joints out of phase?
Cracked flywheel?
Its not the T10; my suspicion is you might dump almost 3k for a hurst driveline conversion and still have the same problem. Do your research on the TKO and T45s, some people really really dislike them, others love them. Check all your crossmember bolts and engine mounts just to cross things off the list
  #24 (permalink)
Old 09-22-2011, 12:48 PM
6426yy's Avatar
Looks to me like you have oil or something leaking on your flywheel. It's glazed over and look at the outside edge of it. Looks like oil as been flung off of it, straight lines going from the center out bottom left picture. sure you don't have a rear main seal leak or possibly a freeze plug weeping?
Air check on tranny clutch packs Crosley Transmission - Rearend 2 03-25-2007 10:32 AM
79 Trans am, to shake or not to shake Gladis Body - Exterior 9 02-18-2007 10:50 PM
Shake, rattle and what to check? firewood Suspension - Brakes - Steering 14 01-26-2004 04:21 PM
t5 tranny or c6, hydraulic clutch martion Transmission - Rearend 2 08-25-2003 11:29 PM
Tranny shake, rattle &roll Paul Saunders Transmission - Rearend 2 02-09-2002 07:21 PM
