(Clutch or Tranny problem) Shake & Rattle 79'z28 w/SuperT10 ! (Video) - Hot Rod Forum : Hotrodders Bulletin Board
Old 07-22-2011, 07:23 PM
Hi guys we have a problem we are trying to isolate for a couple of days, we have this 79' Z28 with a BW SuperT10 tranny,all rebuilt,new clutch kit pressure plate and disc. coupled to a 355.
This is really annoying,when we clutch from 1st to 2nd on load , the car shakes like a madman !
We swapped the pressure plate for another one, same problem ! If you are careful while clutching you can avoid the shaking,its on certain spot that this happens ...
We were told the clutch disc needs to get used to it because its brand new , new fork,new bearing and mount as well.
I dont think the disc will cause that of a chatter ! It's too much !!! the whole front end shakes ! (specially if you are clutch going uphill) and i can hear a metallic sound near the bellhousing area.
It's too much,we got the flywheel on dial and its correct,its not bent or something ...
Today we decided to record this video because it's getting real bad.
Any ideas ? Thanks !
http://www.youtube.com/watch?v=kIwRtHHxp08
Old 07-23-2011, 06:30 PM
68NovaSS's Avatar
Moderator
Wiki Edits: 9
You sure you don't have teeth missing from the ring gear or the spiders? Is the flywheel and pressure plate tight?
Semper Fi
Old 07-23-2011, 06:32 PM
Yes its tight,not sure if there is a missing teeth wow i hate it
Old 07-23-2011, 06:37 PM
SSedan64's Avatar
Pilot Bushing/Bearing missing in the end of Crankshaft??
Old 07-23-2011, 06:57 PM
oldtimercarnut's Avatar
Sounds like a problem I was just having myself. Things I found that could cause this problem. Did you change the flywheel? May be out of balance. Check the two pins on the back of the motor that alien the bell housing. If they are not out enough the transmission can twist and be really hard on the pilot bearing.
Old 07-23-2011, 07:43 PM
RippinRon's Avatar
Was the flywheel resurfaced with the proper finish?
Old 07-23-2011, 09:10 PM
I'm having a smiliar problem, but still havn't figured it out. But here's some things to check:
Check your tranny and engine mounts. Make sure their bolts are tight and the rubber isn't cracked or really soft from oil.
Also check driveshaft u-joints.
Make sure slave cylinder is tightly bolted on.
A leaking rear crank seal can also cause the problem, but hopefully that's not it.
Check transmission to bellhousing bolts and bellhousing bolts to engine block too.
Old 07-24-2011, 02:59 AM
Yes it was, thanks !
Original flywheel,properly resurfaced , i will check the pins.
thanks !
It's there, thanks !
Tranny mount is brand new,i will double check engine mounts.
U joints are old ones,i will swap them.
Transmission bolts are tight,i took it off last week to check swap pressure plate and see if that was the problem,it was not the pressure plate.
i have some small oil leak ..coming from the spot circled in which i think its strange !
what you think ? thanks !
Old 07-24-2011, 07:27 AM
RippinRon's Avatar
Clutch chatter is from either flywheel or the clutch disc. Clutch discs need to break in but shouldn't chatter like that new. I'd say you have to pull it apart and have a look at the friction surfaces. What kind of clutch are you using?
Old 07-24-2011, 09:09 AM
Hi Ron , its a Zoom performance MU5505-1A clutch kit
we replaced pressure plate for another one and same problem
we haven't test another disc yet because we dont have one thanks
Old 07-24-2011, 10:13 AM
4speed's Avatar
Ohio Firebird Member
Last journal entry: 77 TransAm W72
same problem,, I have a 79 trans am with the borg S-t10.
it shakes the hell out of my dash when I take off in first.
all new every thing in it 2 years ago. been that way from day 1.
Old 07-24-2011, 10:18 AM
Have you traced or tried something ?
i think we are going to get a new disc or ....Hurst driveline conversions !
Old 07-24-2011, 12:12 PM
68NovaSS's Avatar
Moderator
Wiki Edits: 9
I've had broken motor mounts allow the motor to torque up and the fan hit the shroud. Sounds similar but no real shaking to that. If it's happeng it,
it could be twisting things. Do you see any wear marks around the inside of the bellhousing or on the ring gear teeth?
Semper Fi
Old 07-24-2011, 12:16 PM
nope , no marks at all , that's why is still a mistery to me
Old 07-24-2011, 12:18 PM
68NovaSS's Avatar
Moderator
Wiki Edits: 9
The oil leak is very strange, I've never seen the pivot ball hole extend clear into the oil passage, all my vehicles with auto trans' just have the hole open, are there any cracks around it?
Semper Fi
Air check on tranny clutch packs Crosley Transmission - Rearend 2 03-25-2007 10:32 AM
79 Trans am, to shake or not to shake Gladis Body - Exterior 9 02-18-2007 10:50 PM
Shake, rattle and what to check? firewood Suspension - Brakes - Steering 14 01-26-2004 04:21 PM
t5 tranny or c6, hydraulic clutch martion Transmission - Rearend 2 08-25-2003 11:29 PM
Tranny shake, rattle &roll Paul Saunders Transmission - Rearend 2 02-09-2002 07:21 PM
