Clutch or transmission check? - Hot Rod Forum : Hotrodders Bulletin Board
Old 09-21-2007, 09:22 AM
frankenvette's Avatar
Go ahead kid squeeze the wheez
I drive my car a lot, and on 2 occasion within the past couple months, I am shifting into 4th gear (at street speeds) and the gears grind like the clutch is not in. This is maybe one out of what seems to be a couple hundred times. Is this an indication of anything I need to do some preemptive maintenance on? Clutch adjustment seems right, transmission has sufficient fluid. Thought I better clarify this is a Muncie M-21.
Old 09-21-2007, 09:35 AM
clutch or trans
If you have no issue with any other gear selection other than 4th then you should suspect the problem is not a clutch issue.
You may want to crawl under the vehicle and have someone shift it into 4th, engine off of course, and make sure the trans is going all of the way into 4th.
It would be nice if you could correct this problem with only an adjustment.
Old 09-21-2007, 09:50 AM
Henry Highrise's Avatar
Lost in the 60's
Wiki Edits: 4
Possibly a syncronizer going bad.
Old 09-21-2007, 01:17 PM
clutch
Yeah, it does sound like it doesn't Henry.
Old 09-24-2007, 10:10 PM
Operator error. I do the same thing just about as often. Foot accidentally enters speedshift mode, hand does not.
More transmission troubles chrisflock Transmission - Rearend 3 08-10-2007 11:07 PM
Issue with Ford 460 clutch onebadmerc Transmission - Rearend 1 02-22-2007 06:15 PM
Hotrodders Knowledge Base: Transmission - Rearend Jon Transmission - Rearend 0 11-26-2005 06:23 PM
83 Z28 Transmission - YIKES! crandaz28 Transmission - Rearend 4 11-25-2003 07:43 AM
Transmission Converter Clutch (TCC) siskom Transmission - Rearend 1 02-25-2003 03:07 PM
