Clutch Turbo 400: Any Tips on Running'em? - Page 2 - Hot Rod Forum : Hotrodders Bulletin Board
  #16 (permalink)
Old 03-27-2011, 07:52 AM
BOBCRMAN@aol.com's Avatar
Describe a soft-loc clutch.
  #17 (permalink)
Old 03-27-2011, 09:47 AM
3rdmember
http://www.mcleodracing.com/products...B+Soft+Lok.mcl
  #18 (permalink)
Old 03-27-2011, 10:46 AM
Originally Posted by BOBCRMAN@aol.com
Three paddle/pads on the disc, not full round. Sort of Like the big semi-trucks use. Sprung hub just causes weird harmonic type vibrations at certain rpms. Hole was about 1 1/4" in bottom of housing.
Thanks for clearing the issue on 3 & 6 paddle disc Bob. Since this will be mostly street duty, I'll probably go with what's readily available out there. You never mentioned if the pressure plate is a Mopar unit or not - ? but I assume it is.
I'll take a hole saw to my bellhousing so I'll be able to fit a feeler gauge in there. Thanks for feedback. Vic
  #19 (permalink)
Old 03-27-2011, 10:52 AM
Originally Posted by tomslik
i'm thinking maybe the little hole is the vent hole...
hey, how about runnubg a soft-loc or similar clutch to maybe save the input shaft?
I doubt these two tiny holes are vent holes as the front of the bellhousing is wide open without the block plate - maybe more like drain holes but then, who knows...
I checked the soft-loc units and it's a good idea but I would imagine if one had enough horses and tires that bite, the input shaft would still take a beating. Also it'll be hard to justify those prices for a hobby to my wife
  #20 (permalink)
Old 03-28-2011, 11:14 PM
Bob,
Can I trouble you to get a measurement on the adjustment hole - from engine mounting flange to center of 1 1/4" hole?
Thank you,
Vic
  #21 (permalink)
Old 03-29-2011, 04:53 PM
I measured 5" exactly. Hole is 1 1/2"
  #22 (permalink)
Old 03-29-2011, 05:49 PM
Thank you Bob!
  #23 (permalink)
Old 03-30-2011, 05:25 PM
I measured 5" back and it seems it's real close to the tranny - too far back to take a clutch clearance measurement. When I get my clutch back, I'll mock it up and see. Any chance of a picture? Thanks, Vic
