Clutch Turbo 400: Any Tips on Running'em? - Hot Rod Forum : Hotrodders Bulletin Board
Old 07-24-2004, 09:33 PM
I have a '78 Malibu small tire car with a fresh 13-1 BBC and a clutch-turbo in it, and I was wondering if anybody remembers any stories or tips on running'em. I've heard enough reasons why I should convert to an automatic-NEVER!! I'm a clutch guy for life and that's not an option. I've already got a bunch of money tied-up in this trans: fresh rebuild w/new clutches inside,etc., new Mcleod "special" clutch/pressure plate/t/o-bearing, deep B&M pan w/fins, TCI reverse manual valve body, and Kilgore 2.75 low gear set. I set the car up according to NHRA's rule book to run 9.90, should I put a "real" motor in it someday. I did learn what that "little hole" in the bottom of the bell-housing adapter is for now. While running through the valves for the first-time fire up, I noticed a little trans fluid on the shop floor. I found it to be comming from that little hole. I've never noticed it before. After calling friends around town, the best advice I got was to just plug it. BIG MISTAKE!! Two Minutes after fire-up, I had to shut her down. Trans fluid was everywhere! The fluid had proceded down the imput shaft coated everything inside the bell housing under pressure. I blew a seal and that little hole was trying to let me know. My full-automatic friends say at least the clutch won't rust! Any other tips on this set-up? How much power can they handle? What RPM can I launch it at? (I'm afraid to find out the hard way!)
It's street legal (except for the race gas) and I can't wait to take a late night ride and set off all of their burgler/car alarms!!
Old 07-27-2004, 06:35 PM
BOBCRMAN@aol.com's Avatar
I ran a Fairbanks Clutch Turbo, in an early tube chassis, glass front end, BIG BLOCK Nova bracket car. The trans only has one flaw and that is the one inch, fine spline input shaft.
You can launch this trans wherever you are making power, but if you run big sticky tires on a "Bitey" strip. You will twist that input shaft! I used to have half a dozen or so hanging in the barn. I would paint them with a white or yellow stripe when new and these all look like barber poles!! The material is tuff but not large enuff to take the "Drop the hammer,no spin" 15" wide tire starts.
My setup used a six paddle Ram clutch and the three finger Long style press plate. Never had a leak problem tho.
Old 07-28-2004, 07:22 AM
Hey thanks. I'll do that -paint a line on the input shaft. It's a 23 spline Chrysler input shaft. As I am not familiar with automatics I assume this shaft originally comes from a 727 Torqueflite. Would you know? It would help to know so I know where to get a replacement, or spares. I have a McLeod Long style PP with a sintered iron disk and solid marcel. It's a fresh trans with all new parts, I cut the case myself(already cracked across the bell housing from using the wrong flexplate) that some guy was throwing out. Ibuilt it 2 years ago and never ran until now, and a friend says that it sat too long and tore-up the seal upon start-up. Another says I need to index my scatter-shield before putting it back in. Also, some say to use a solid trans mount but I felt since I already have solid motor mounts, I 'd better go with just a brand new stock rubber unit. I have no mid-mount. What have you used with your previous unit? Thanks again.
Old 07-28-2004, 08:38 AM
As far as I know the input shafts were made for the 400 trans. They were not Chrysler. Even tho they used the Mopar spline, the shaft was a custom piece. Made of what they used to call "Hi-Tuff" steel.
As for mounts. This was a somewhat flexible car, ahead of the firewall. For that reason I ran Solid engine mounts and a rubber trans mount. I hate broken housings. I see a lot of them in other peoples cars.
My trans was dialed into the rear of the engine with offset dowels. Fairbanks did a very good job on the conversion and with the Lakewood housing, very little adjustment was required.
I also tried the solid hub, but the Ram sintered paddle type disc was easier on the input shaft.
Good luck! If the input shaft problem hadn't existed, I'm sure more of the trans' would be around. I loved mine but you can't win if you don't make the next round due to breakage.
Old 10-16-2010, 01:15 AM
Cooling
There's no mention about a tranny cooler. Is it necessary to install a cooler if running a clutch turbo on the street? I know there's no converter to generate heat but I'd think just the internals working would generate some heat. Thanks!
Old 10-16-2010, 05:21 AM
Actually I would run a radiator mounted cooler just to get the trans up to operating temp.
Old 10-16-2010, 09:22 AM
cooler
Bob, when you say "UP" to operating temp., do you mean that it WON'T get hot enough? I checked where the cooling lines would hook up to the tranny and it's plugged. I was told on another site that I would need to do something to the pump in order to make fluid circulate into the lines and cooler. I'd like to circumvent this option if at all possible. I am purchasing a tranny temp gauge and will run that just to see how hot it'll run. I was told if it'll stay around 200 degrees, it won't be a problem. Any thoughts on this?
Thanks,
Vic
Old 10-16-2010, 11:15 AM
junior stocker's Avatar
The "hole" is'nt a drain; it's for setting the clutch clearance with a feeler gauge.
Old 10-16-2010, 01:56 PM
My trans cooling lines were plugged. The pump was also plugged..
Aa a Drag race trans, with high metallic frictions nobody worried about the temp. But, as a street trans. Modern fluid is designed to operate at higher temps. A radiator trans cooler would get trans to operating temp faster and hold temp better..
Old 10-16-2010, 03:28 PM
Hole?
Not sure what hole you're talking about. Yes, I know the clutch needs to be adjusted.
Old 03-26-2011, 06:36 PM
Bob,
I hope you're still on this site. What clutch assy. does the clutch turbo take? I assume it's a Mopar with 23 spline w/ 1" input shaft on 10 1/2" unit. Is the pressure plate Mopar as well? The 3 fingers on the pressure plate sticks up for the spider to engage but not familiar with which pp that is. I need to replace the clutch and assume it's a Mopar but wanted to check before investing $$$. This unit will be street/strip so which disc would you recommend - organic or organic/metal?
How does one measure .075 - .080" clutch play? I can't seem to get a feeler gauge into the blowproof bell housing to measure that.
Thanks for your time Bob, any help will be greatly appreciated. Vic
Old 03-26-2011, 08:00 PM
I always used RAM three finger 11" (Borg&Beck style) pressure plates. Three wide fingers. In a non shifting unit like clutch/turbo. Use a solid hub disc. I tried organics and metallics but I was partial to the Three and six sintered paddle disc. Bites like you won't believe. The three paddle is easier in the 1" input shaft. After The supply of Mopar splined shafts dried up I went to 1" coarse (GM) spline shafts, made locally. Still have a couple of new discs 11" for those.
The older Lakewood shields had a hole in bottom to measure clutch release.
I have one in the shop window for display. Along with old tunnel rams and dinosaur stuff..
Old 03-26-2011, 10:14 PM
Summit Racing sells the 23 spline Mopar 3 finger clutch which I am thinking of trying. These are organic/metal disc but not solid hub. You mention a 3 & 6 sintered paddle disc - what are these, 3 or 6 individual pads on the disc?
My bellhousing has two small holes (looks like drain holes) on the bottom so no way of sticking a feeler gauge in there to check clearance. How large is the hole in your bellhsng? I may just have to drill the hole large enough to accomodate a feeler gauge.
Thanks, Vic
Old 03-27-2011, 07:22 AM
Three paddle/pads on the disc, not full round. Sort of Like the big semi-trucks use. Sprung hub just causes weird harmonic type vibrations at certain rpms. Hole was about 1 1/4" in bottom of housing.
Old 03-27-2011, 07:41 AM
3rdmember
i'm thinking maybe the little hole is the vent hole...
hey, how about runnubg a soft-loc or similar clutch to maybe save the input shaft?
