clutch Z bar - Hot Rod Forum : Hotrodders Bulletin Board
Old 07-01-2011, 06:12 AM
Don Meyer's Avatar
clutch Z bar
I am converting a 65 Biscayne to a 4 spd trans. I bought a Z bar at a swap meet that has a 1: 1 ratio(both arms are the same length).
Being 73 yrs old I want to minimize the clutch petal effort.
I want to make the input arm longer......anyone have a zbar from a SBC they can measure the arm lengths.
thanks Don
Old 07-01-2011, 06:53 AM
Wiki Edits: 27
drill time
When I had the Buick nailhead and a BW T 85 Od in my willys I drilled a few more holes in my z bar then moved the linkage hook ups around until I got the effort and pedal at rest height I liked.
Old 07-01-2011, 12:49 PM
Rickracer's Avatar
ASE Master Tech, Fabricator
Last wiki edit: Taurus 2-speed fan control wiring diagram Last photo:
Hey Don, you're CLOSE, I used to work at St. Cloud Texaco. Have you considered going hydraulic?
Old 07-01-2011, 02:26 PM
Don Meyer's Avatar
I did hydraulics on my cobra, but found no advantage to it & the cost is higher.
Don
Old 07-01-2011, 04:37 PM
cobalt327's Avatar
WFO
Wiki Edits: 1616
The Moore family still own the Texaco? That was a long time ago...
Don, if you still need the arm lengths, let me know and I'll go out and measure one.
Old 07-01-2011, 04:39 PM
I'm running about 7:1 ratio in my T , w/B&B pressure plate , ratio seems within reason & I'm 63. The type of p/p you use will make more difference than anything IMHO
dave
Old 07-01-2011, 09:42 PM
Rickracer's Avatar
Originally Posted by cobalt327
The Moore family still own the Texaco?....
I have no idea, it's been like 18 years since I worked there.
Old 07-02-2011, 07:59 AM
Bryan59EC's Avatar
Car? Truck? Who Cares
Last journal entry: First week of December
A fairly stock replacement Diaphragm type pressure plate is all you will need.
No matter what you do--you will still need to maintain about 1" travel at the end of the fork.
Messing with ratios could make this impossible.
Clutch in my old Chev truck was a bear with the 12" Borg&Beck.
Like pressing a marshmellow with an 11" Diaphragm
I am using a hydraulic clutch in the 59 Elky----88 Chev truck master with an 87 bellhousing and slave-------pretty easy operation---but a pain to bleed.
Have a 10.5" Diaphragm in my 66 Elky with stock ratios and it is pretty easy to operate.
Old 07-02-2011, 08:58 PM
cobalt327's Avatar
WFO
Wiki Edits: 1616
Nevermind- I was talking about ca. 1970-ish.
Old 07-02-2011, 11:19 PM
Wiki Edits: 27
easier pedal
I broke about 20 bones in my left foot-ankle, My F 350 dually is tiring and brings back the limp , one of the tractors is also hard for me to drive. I redid one car that I had put in a HD clutch, changed the ratio and reworked the pedal stop to have a little more travel with less effort.
Help in a clutch :) garretthes Transmission - Rearend 1 05-28-2007 04:35 PM
10 !/2 clutch or 11 inch clutch retired 56 Transmission - Rearend 8 03-26-2007 06:52 PM
what clutch? chris oswalt Engine 1 02-28-2006 09:06 AM
Clutch help 79transam Transmission - Rearend 3 12-19-2004 11:15 PM
Lakewood Clutch fork clip broke/angle of clutch fork 70bird Transmission - Rearend 3 04-23-2004 07:04 PM
