clutchturbo400 - Hot Rod Forum : Hotrodders Bulletin Board
Old 05-07-2011, 10:53 PM
clutchturbo400
me ande my boy have a 76alston tube chassis a arm suspension vega with a 383 smalllock chevy dana rearend with a new clutchturbo 400.we installed the trans with a new pressure plate and cluth disc and when you step on the cluth pedal the pedal will not go down to release the clutch. it has manual linkage. is there a lineup procedure .this is my 3rd transmission i ve used in the car which we have ran for 30yrs. off and on i remember it calls for a .040 or .050 air gap when the clutch pedal is pressed to the floorbut the is not going down
Old 05-08-2011, 08:26 AM
Possiby you don't have the correct throw out bearing.Do you have the long or short one installed?Could be the springs in the pressure plate are too weak.
