Hot Rod Forum : Hotrodders Bulletin Board - View Single Post - CMC '34 Coupe 1992 Build
Old 12-04-2008, 01:02 AM
NEW INTERIORS NEW INTERIORS is offline
life is a temporary assignment
I think your car came out very nicely,But there is still some problem's's that you left the same on your car ,as all CMC car's.It can't be removed from the frame if had to.That's my biggest complaint I have with these car's.Then there the gap between the fire wall and the toe board.I see on your car you built it pretty much as the manual say's to build it.
Not trying to get on you bad side now,Just pointing out something's.
This is how I glassed my trunk. I made the floor all one piece.All water tight.
ID:	34746   Click image for larger version
ID:	34747   Click image for larger version
ID:	34748   Click image for larger version
