cng - Hot Rod Forum : Hotrodders Bulletin Board
Old 12-06-2012, 06:38 PM
cng
Building a cool little Honda 120cc that is currently at the machine shop, It will see some propane every now and then, how much hotter will this run? Its on 100 octane and 12:1
Old 12-07-2012, 08:04 AM
bondo's Avatar
cng
Ayuh,... Yer question is sorta hard to fathom,...
In the title, yer askin' 'bout compressed natural gas, 'n in yer post yer askin' 'bout Propane...
Yet, you also say it'll see propane occasionally,...
What's it gonna be runnin' on Normally,..??
All 3 fuels are quite different, 'n the induction systems vary quite abit for each fuel...
In other words,... Alot more Info is needed for any kinda answer....
Old 12-07-2012, 08:17 AM
Wiki Edits: 27
optimum CR ?
Each fuel also .has an optimun compression ratio
Old 12-07-2012, 08:33 AM
I was under the impression that cng and propane were the same. Sorry
Old 12-07-2012, 12:56 PM
hcompton's Avatar
Old & Furious
They are but usally at different psi so you need different regualtor.
Propane can not be used in an engne with gasoline as well. That trick is desiel only. Propane needs a special carb and cant not be blown into the gas carb.
What type of engine for what purpose. A small engine dragster or a pit bike? Kinda left a lot of room in that one. Go kart lawn mower generator golfcart
Old 12-07-2012, 03:54 PM
Its just a mini bike motor amenities have used propane on a Briggs 9 HP and it worked great. Almost a full HP gain.
