Coating on aftermarket panels ( E- coat ) - Hot Rod Forum : Hotrodders Bulletin Board
Old 03-04-2009, 02:07 PM
A guy wants me to paint his hood on a 2000 chevy ( s10 ) blazer.
He just put it on ( aftermarket ) and installed blanket underhood.
His concern : Should I paint the underside of hood also ( which would require him to remove hood again) or will the coating be sufficient that is on it ?
Costs is a factor for him.
Any advice appreciated.
Old 03-04-2009, 06:35 PM
Old Fool's Avatar
Are you sure it is e-coat?
OEM replacement sheet metal is e-coated, some aftermarket sheet metal is e-coated, but an awful lot of it is the cheapest black primer they can apply.
Pick a spot and rub it real good with a lacquer thinner wet rag.. if nothing happens then its more than likely e-coat. If not it is the chinese special.
Either way I would coat the underside of the hood with the same finish you are putting on the topside.
Old 03-04-2009, 08:51 PM
Bee4Me's Avatar
Problem Child,Hard Case
Last journal entry: Strangest job I've ever done
If it is real e-coat,outside of it looking like crap,it will "do".
Drill a couple of 1/8" "alignment" holes in both of the hinges.
This way you won't monkey up the paint putting it back on and getting it aligned.
With having the blanket,your paint work won't have to be "great",just enough to make it "respectable".
Old 03-04-2009, 10:01 PM
mitmaks's Avatar
Last journal entry: Grille
I would abrade it very well with scotch brite and shoot some sealer over it.
Arrrgg! Clear coat flaking off!! dpowers Body - Exterior 16 04-01-2008 11:10 AM
replacement rocker panels ArmyofOne Body - Exterior 8 01-22-2007 05:57 AM
base coat clear coat wally Body - Exterior 8 12-12-2005 06:44 PM
laminating- gel coat pre-release powderbill Body - Exterior 5 06-12-2005 05:59 PM
Can I Spray Clear Coat Over Clear Coat ??? STATUTORY GRAPE Body - Exterior 2 10-07-2003 09:09 AM
