Coating of Cast Iron exhaust manifolds, anybody done this? - Hot Rod Forum : Hotrodders Bulletin Board
Old 11-21-2005, 09:53 PM
I have existing cast iron exhaust manifolds that I know to fit, they are on the car now. I would like to have them coated with silver ceramic coating such as..."Jet-Hot" or equivalent.
Has anybody done this? How did they turn out?
Do they chemicaly strip the old rust and dirt off the inside and outside then coat? Did you have to do any prep work yourshelf (grinding, rust removal, sanding, ect...,) before sending them in?
Any input is appreciated, this is on a big block Chevy motor running 1972 Impala exhaust manifolds
Thanks in advance, Tom
Old 11-22-2005, 12:36 AM
Before sending them off I would remove any casting flash on the manifolds with a die-grinder. At Jet-Hot there is a multi-step process including: thermal degreasing, abrasive-blast stripping with virgin aluminum oxide, double-coating (inside and out), high temperature curing, custom packaging for return shipping, and quality-assurance controls during every phase of the procedure.
Old 11-22-2005, 08:19 AM
Anyone ever use this stuff? the manufacture says it is the same stuff the pros use. It says it is good to 2000 degrees. The price for the material is much cheaper than sending parts out.
http://www.techlinecoatings.com/Exhaust.htm
I also want to do my SBC Rams horn manifolds. I have heard and seen some people use the eastwood silver paint. It looks good when new but not sure about life span.
Old 11-22-2005, 08:55 AM
I had Jet-Hot do mine....about 2 or 3 years ago.
They look as good today as the day I took them out of the box.
Like already said......clean the casting flash....I sandblasted mine.....inside and out...
It really helped with the under-hood temperatures.
Old 02-12-2007, 08:35 AM
how much did it cost to have it done??
how long does it take from the time you sent them off, till the time they returned?
What has been your experience with headers compaired to stock exhaust manifolds?? Jim Weeks Engine 10 10-06-2012 12:21 PM
Jethot Coating Manifolds RickB1B Engine 2 06-14-2005 09:21 AM
Best Rust Inhibitor? bigbrowndog Body - Exterior 45 11-21-2004 09:26 PM
Exhaust manifold coating terry65elcamino Engine 2 01-08-2004 08:52 AM
Exhaust coating golfpro Body - Exterior 1 05-08-2003 03:19 PM
