coats 20-20 tire machine problem - Hot Rod Forum : Hotrodders Bulletin Board
Old 05-08-2010, 03:09 PM
I have a older coats 20-20 tire machine i picked up, everything works on it except when i attach the bar to the centre post to remove the tire it spins so fast to the point its dangerous. Its not a air pressure issue i played around with that and it still does the same thing. Is it possible the machine is low on hydraulic oil? I;m going to check that but was wandering if theres something else i should look into while i have the cover panels off? Any help would really be appreciated.
Old 05-08-2010, 06:49 PM
matts37chev's Avatar
& matts38chev
Last journal entry: Try again
whats the return speed like?
Old 05-09-2010, 12:44 AM
I think the return speed is fine but i will check again in the morning. Thanks
Old 05-13-2010, 08:15 PM
return speed
The return speed is normal, not sure what that means? I will take it apart tommorow and see if its just low on oil, i'm just wandering if someone familiar with these machines may have some suggestion what else may cause the centre post to turn so fast that it is actually dangerous. Thanks hope someone can help me out with this problem.
Old 05-13-2010, 08:35 PM
& matts38chev
mine is slow and weak and the return almost doesnt work at all
i havent bothered to look into it didnt know if they are related
does anyone know anything about old analog spin balancers mine wont spin
Old 05-14-2010, 05:36 PM
Old Fool's Avatar
Do the hydraulic circuits have flow controls ? Possible the forward is full open and the return is correct?
Old 05-15-2010, 01:28 AM
I really have no idea i'll take the cover off and look but i'm not sure what i'm looking for? I'll print off a parts diagram off the internet maybe it will show something on there.
I Think Someone Doesn't Like Me. (3rd tire problem) Ghetto Jet Hotrodders' Lounge 12 05-22-2009 05:15 AM
A Tire Happenings Synopsis hobbytires General Rodding Tech 21 12-03-2007 05:18 PM
Mickey Thompson Radial Tire Problem Pro57 Suspension - Brakes - Steering 22 10-25-2007 07:30 PM
Spare tire problem fred56 General Rodding Tech 13 03-04-2007 05:59 AM
How to determine effective tire diameter sabino56 Transmission - Rearend 19 10-27-2006 09:19 PM
