Coax TV cable compatable with power cable - Hot Rod Forum : Hotrodders Bulletin Board
Hot Rod Forum : Hotrodders Bulletin Board > General Discussion> Hotrodders' Lounge> Off-Topic
Old 02-01-2011, 10:29 PM
I have cable TV in the house and want to run it out to a detached garage using a splitter. I am running 2-2-4-6 direct burial cable (240 volts)to the garage for power.
My question is can I put the coax cable for the TV in with the direct burial power cable without getting any interference with the picture on the TV?
Old 02-02-2011, 06:17 PM
302 Z28's Avatar
Not a good idea, even though the TV cable is shielded it could pick up induced voltage from the 240vac. In industry we make a point of running low voltage (24vdc, 1-5vdc) in a separate conduit or cable tray away from any and all higher voltages.
Vince
Old 02-02-2011, 06:24 PM
poncho62's Avatar
Wiki Edits: 5
At my old house, I had the TV cable in the same underground pipe as the 220.....It worked fine.....not saying yours will....just saying mine was OK
Old 02-04-2011, 01:39 PM
curtis73's Avatar
Hates: Liver. Loves: Diesel
Wiki Edits: 16
I wouldn't. At the very least it will muck up the signal. At the very worst, I think placing a load on the 240 can make some pretty impressive induced voltage in anything around it, so you run the risk of frying the tuner in all of your TVs on the circuit.
Standard code here says 18" away from 240v, 12" away from 120v. Most electricians just run it in the next studspace so its 16". I have also put my outlet boxes on either side of the same stud with no problems, but the cables are run on the next stud away, so they're only together for the last couple inches.
tv cable tommy evans Transmission - Rearend 8 08-03-2010 02:58 AM
Just what is this cable for? MARTINSR Hotrodders' Lounge 37 05-01-2010 09:43 PM
cable vetteman Transmission - Rearend 0 07-03-2004 08:05 PM
Cable Tv Knobie Transmission - Rearend 10 03-11-2004 02:51 PM
TV Cable MI2600 Transmission - Rearend 2 09-05-2003 07:26 PM
