-   Modern Electronic Engines (http://www.hotrodders.com/forum/modern-electronic-engines/)
-   -   Cobbling in some O2 sensors (http://www.hotrodders.com/forum/cobbling-some-o2-sensors-218082.html)
Silver Surfer 04-12-2012 11:52 AM
I have some left over wideband O2 sensors from my daily driver. I was thinking about welding in two bungs on my carb'd hotrod truck to see how close the jetting is. I would prefer not to hack into the long tube headers to get accurate readings. Can I go in through the exhaust tubing? Does it matter?
T-bucket23 04-12-2012 03:15 PM
If it is temporary they sell clamps with a bung in them. They are more of a sleeve than a traditional clamp and you wont have to destroy anything.
Silver Surfer 04-12-2012 03:32 PM
I like the idea of a temporary jig! What do you mean by clamp? Where/how does it attach? Do you have a link this?
T-bucket23 04-12-2012 03:41 PM
Here you go. google is your friend :D
Summit O2 clamp
75gmck25 04-12-2012 07:27 PM
Are they heated OEM sensors, or just a single wire O2 sensor? With heated sensors you can put them in just about any section of pipe before the CAT and still get a reading. If they are unheated they need to be close enough to the engine for the exhaust to heat them up.
You also need to mount them vertical, in the range between about 10 and 2 o'clock so that condensation in the exhaust does not pool on the sensor. In other words the plug on the sensor needs to point relatively straight up, not down or to the side.
Bruce
