Cobbling in some O2 sensors - Hot Rod Forum : Hotrodders Bulletin Board
Hot Rod Forum : Hotrodders Bulletin Board > Tech Help> Engine> Modern Electronic Engines
Old 04-12-2012, 11:52 AM
Silver Surfer's Avatar
More machine than man
Last journal entry: bwaahhaahahaaahhaa
I have some left over wideband O2 sensors from my daily driver. I was thinking about welding in two bungs on my carb'd hotrod truck to see how close the jetting is. I would prefer not to hack into the long tube headers to get accurate readings. Can I go in through the exhaust tubing? Does it matter?
Old 04-12-2012, 03:15 PM
T-bucket23's Avatar
Wiki Edits: 26
If it is temporary they sell clamps with a bung in them. They are more of a sleeve than a traditional clamp and you wont have to destroy anything.
Chet
Old 04-12-2012, 03:32 PM
I like the idea of a temporary jig! What do you mean by clamp? Where/how does it attach? Do you have a link this?
Old 04-12-2012, 03:41 PM
T-bucket23's Avatar
Wiki Edits: 26
Here you go. google is your friend
Summit O2 clamp
Chet
Old 04-12-2012, 07:27 PM
Are they heated OEM sensors, or just a single wire O2 sensor? With heated sensors you can put them in just about any section of pipe before the CAT and still get a reading. If they are unheated they need to be close enough to the engine for the exhaust to heat them up.
You also need to mount them vertical, in the range between about 10 and 2 o'clock so that condensation in the exhaust does not pool on the sensor. In other words the plug on the sensor needs to point relatively straight up, not down or to the side.
Bruce
Recent Modern Electronic Engines posts with photos
O2 sensors burning out 2000TAinNE Engine 6 07-07-2009 08:30 PM
low-only sensors usmcsawgunner Engine 6 01-27-2009 08:07 PM
A bunch of sensors? BRSleeper2 Electrical 4 07-22-2008 04:07 AM
Sensors fatdawgy Introduce Yourself 1 08-13-2007 12:54 AM
Sensors woodmanscott@hotmail Engine 4 03-11-2007 01:27 AM
