Cobra trans selection - Hot Rod Forum : Hotrodders Bulletin Board
Old 12-28-2011, 08:21 AM
Building a b&b cobra kit with 8.8 ford rear end and 351C
Need a transmission with the shifter way forward
What is the best option for manual transmission?
Old 12-28-2011, 08:35 AM
S10xGN's Avatar
Gotta love a turbo!
TKO-500 or 600 both have several places for the shifter location... Check out the Keisler or D & D Performance sites and see if the shifter locations will work for you...
Russ
Old 12-28-2011, 01:37 PM
Another option would be a T5 WC unless you're going to abuse it. Gforce makes a 5spd too, the G5R. You could look into a Ford T10 or Toploader with a deeper 1st gear and run a lower axle ratio as well (for instance a 2.56 1st with a 3.55 rear)
My cobra corba1966 Introduce Yourself 1 05-11-2011 04:38 PM
cobra jet deven Engine 5 11-09-2006 08:07 AM
283 / steel crank/ trans selection el Transmission - Rearend 1 08-20-2003 01:10 AM
Gear selection for my Trans am Hot Rod/SS Transmission - Rearend 1 02-12-2003 02:11 PM
What is a Cobra? USMCDCC Engine 20 11-27-2002 11:11 AM
