code reader
I scanned our car and it gave me a P0401 code. Definition is Exhaust Gas Recirculation flow insufficient detected.
So is it pretty much saying that I need new EGR valve? I heard you can just rebuild them, clean them up. Its $150-$200 part at the store. Maybe I dont need it, any suggestions |
You didn't say what make this is, but on GM I've opened them up and found tons of carbon buildup, cleaned it up and was good to go. There's really nothing to them, never fear.
Midnight Sun Street Rod Association |
More information about what type of vehicle would make it a lot easier to help you. If it is a ford remove the valve and clean out the passages, also sometimes on the ones with a corrugated type steel tube, this rots out. If it is a Honda, you can pull the upper plenum and the EGR and clean out the passage. |
this is on 96 lexus ES300. Ive ran a half of bottle of sea foam before but that didnt help. Check engine light still came up after I've reset ECU.
Seafoam is not going to clean out the exhaust ports of teh EGR housing. Pull the EGR valve and follow the port away from the valve, I bet you find one of them is plugged solid or close to it. A galley brush, or a coat hanger and some carb cleaner will usually do the trick. Try to get it as clean as possible as the sludge that builds in there adds up fast once it starts. The cleaner you get it the better off you will be.
Ok I did some Digging in old notes, there is a VSV that controls the EGR that has caused that issue, the more common fix was removing the throttle body and cleaning out the EGR port. I have several notes on tehis for toyota/Lexus repairs. I would try cleaning the port out first before you buy any parts
Chet |
ive ran some wire inside of lines that lead to EGR and out of it, didnt see or feel any build-up. Can I spray some throttle body cleaner in there and see if that will clean up any build-up it might have? So I'll need to take apart EGR valve and clean it up?
alright. so I took it all apart last weekend and cleaned it up and put it all back together. Cleared code with my code reader and CEL hasnt came back on yet.
damn code came back after over a week...
just an update. I bought vsv valve and replaced it, after about a week or so CEL turned off by itself.
| this is a saver.... GM build codes | TooMany2count | General Rodding Tech | 24 | 11-23-2009 09:36 AM |
| Pontiac 400, XF Code | Houston54 | Engine | 5 | 11-02-2007 05:32 PM |
| Code Reader ? | Theresa Shank | Electrical | 5 | 08-11-2007 07:23 AM |
| Code reader??? | cabrio | Garage - Tools | 8 | 01-22-2007 09:33 PM |
| 96 impala SS Code P0140..Help!! | olimpalarider | Electrical | 2 | 01-20-2007 03:58 AM |
