ok little bit of an up date. taped off what i could ( steering wheel, gas and break pedal) ,took off the floor board. put on 3 coats of primer then 3 coats of HOK black then 3 coats of HOK clear.. got a little bit of solvent pop but not all that bad i mean you have to be at least 12' away to really see it . so im just gonna wet sand where its not covered anything under the body im not worried about probably sand only where the motor is back to the box. took a piece of diamond plate 24x10 and made a place for the gas tank to be laid to rest. the radiator is alium. model T type so i can just polish that
