coffin car build - Page 7 - Hot Rod Forum : Hotrodders Bulletin Board
  #91 (permalink)
Old 02-08-2012, 05:41 PM
wow they put a good chunk of change in it just for a prop car id love to have rader rims and slicks
  #92 (permalink)
Old 02-10-2012, 03:26 AM
here is some of the new lining for the top of the lid. pics are a little dark . the blue buttons will be covered with the purple as well 1" HD foam glued to the cardborad . for the sides i was thinking of maybe just adding a few pleats, this stuff shines nice. still got to come up with a way to attach it to the body the factory used a cripper to attach the satin to the sides . i tryed to do the seat in diamond tuff but didnt work so i just used that spray adhesive and wraped it in the velvet put this on and with the polished alium floor boards i think it will come out nice ..... any one live near cherry hill nj area that has a pipe bender maybe help with a small roll bar? really didnt want to go to HF and spend 100.00 and use it once could be a decent investment i guess probably be the last thing that goes in the car besides me
ID:	62822   Click image for larger version
  #93 (permalink)
Old 02-10-2012, 07:40 AM
I have to tell you, that is creepy.
  #94 (permalink)
Old 02-12-2012, 04:39 AM
what it doesnt look right or its just creepy to have in a casket? i am pimping my ride a bit just like the guys with the lowriders if you watch " munster go home" when they rebuild the drag u la the casket has the same pattern (only on half the lid) looks kinda kool looking
got my block back yesterday will start putting that back together this week everything seems to be going as planed i think even if i had a garage it would be darn cold to work in right bout now even with heat. only 2 more weeks and this winter is history i hope then hello springtime
  #95 (permalink)
Old 02-12-2012, 10:59 AM
It looks perfectly "right" in a casket, THAT is what is so creepy!
  #96 (permalink)
Old 02-12-2012, 06:45 PM
31 five window
Last journal entry: Moving along with patch panels.
I think it is way cool.
  #97 (permalink)
Old 02-18-2012, 05:35 PM
well got the diamond plate cut and mounted for the floor and the shifter mounted what job cutting with a skill saw nice and slow and add water to cool the blade will post pics tomorrow. also this week got the crank and pistons, oil pump, and comp cam, and timing chain on the motor, tomorrow put the heads and lifters in and roller rockers. hopefully we can test fire this on monday if not theres always next weekend getting closer now .... starting look like a automobile. probably will have to be next weekend we have to run wires and etc but hell its coming
  #98 (permalink)
Old 02-19-2012, 04:27 PM
casket interior
oh little up date on my build we added more steel to the steering, added some gusets to each corner of the frame for a added support. i was thinking of adding some diamond plate to cover the steering rod and set gauges on top, with a key switch on bottom just wanted to see what the seat and some velvet looked like with the floor . test fit the top section of the lid. also put on the plastic or foam trim around the top of the lid putting a different patteren along the bottom then filler along the edges and prime jeepers creepers its coming along all the time is this gonna be a kool ride or what?...
of corpse it is
Name:	casket interior.jpg
ID:	63113   Click image for larger version
ID:	63114   Click image for larger version
ID:	63115   Click image for larger version
ID:	63116   Click image for larger version
  #99 (permalink)
Old 02-19-2012, 04:29 PM
a few more pics
ID:	63118   Click image for larger version
  #100 (permalink)
Old 02-19-2012, 04:43 PM
TucsonJay's Avatar
I did this helmet many many years ago, for a drag bike called "Bone-Zai". It seems like a natural for your project. ...less the samurai headband of course. :-)
  #101 (permalink)
Old 02-19-2012, 05:08 PM
nice airbrush work on that my friend, i do airbrush too, maybe make something like that just set on the seat
  #102 (permalink)
Old 03-04-2012, 07:45 PM
well today i got the new wheel cylinders in and the breaks bleed. got the new rims mounted on the slicks i found a place that i can get replacement cardboard for the top lid lining these got damp and started to curl a bitfound a olace on line for onlays for the trim i thought we would have gotten it started running by now the engine is just about ready and it rained the last 3 weekends here so we couldnt get it in the frame think bout buying one of those shelter logic temp garage 10x20 that way we can get more done in the evening and being its only 11ft long thatll give us plenty of room to move around at least i think it will the first car show is the 16th of april i dont think we will amke that one more likely may
  #103 (permalink)
Old 03-05-2012, 03:58 PM
new rims
got these mounted yesterday 15x8 rims got these off of speedway motors kool knockoff of a Rader wheel the center caps i was thinking of spraying black and adding a white spider web design.. The only thing is these are not deep dish type. and my slicks are only 9 " wide these will work fine cause the trailer im doing mods on is only 75" wide between the tires ... if they were deepdish with a smaller back space the car would fit on the trailer
  #104 (permalink)
Old 03-05-2012, 04:02 PM
I love those wheels!
  #105 (permalink)
Old 03-07-2012, 03:07 AM
Well started sanding some of the trim work omg what chore got the top course done ordered some more onlays for the casket trim, Lowes or home depot dont have a lot to chose from. measured and installed the new casket handels coming alone really well. the weather is warming up all the time and i have a 3 day weekend
build thread
HELP!!Building a coffin hot rod! scheiderer68 Hotrodding Basics 15 03-22-2013 03:15 PM
munsters coffin dragster scheiderer68 Hotrodding Basics 21 10-26-2011 03:07 PM
355 build??'s about compression and build impalaman355 Engine 6 06-06-2011 10:20 AM
USA BUILD vs CANADIAN BUILD? troy norrad Hotrodding Basics 19 02-18-2008 09:57 PM
200-4r experts - build questions - Which core is best to build on? Warrant Transmission - Rearend 7 10-09-2007 07:36 PM
