coil bind??? - Hot Rod Forum : Hotrodders Bulletin Board
Old 04-04-2006, 05:16 PM
coil bind???
hi evryone, i've recently picked up some 1.6 pro magnum rockers and i am concerned about the potential for coil bind. is there anything that i can do with everything assembled as normal to check for this? i am also not sure of the installed height of the springs which i am sure adds abit of curve to answering my question. i guess its obvious that i'm very green at the finer details of heads. any tips or suggestions to try would be greatly appreciated as i don't want to risk damaging parts.
thanks for your time.
keith
Old 04-04-2006, 09:45 PM
BOBCRMAN@aol.com's Avatar
After determining your installed height. Mock up a valve/spring/retainer assembly. Set it up in a drill press or vise and compress the spring to your cams lift with the 1.6 rockers. Then try to insert a .060 feeler guage between the coils. If it fits you are ok.
If the head is on the engine. Crank engine assembly over till valve is at full lift and measure with feeler.
Old 04-06-2006, 08:01 AM
thanks for your response. does rpm affect coil bind at all? i am to assume that i should check multiple coils per spring and also each spring individually?
thanks again.
keith
Ignition system info................ poncho62 Electrical 18 10-11-2008 11:10 PM
Ignition Coil resistance Question Old School Nut Engine 3 06-11-2005 04:36 PM
Push botton starter street rodder 1937 Electrical 4 03-17-2005 10:19 AM
No Spark at Coil/ 350 SBC 1966impala Electrical 4 10-01-2003 01:07 PM
coil bind in 350 sbc finman Engine 8 07-16-2003 12:25 AM
