Hot Rod Forum : Hotrodders Bulletin Board - View Single Post - Coil Failure after heat up
Old 07-27-2003, 09:36 AM
72 gmc 72 gmc is offline
New Member
the coil would be suspect in this case but if you still have the original ignition setup ie points and condensor i would be more suspicious of the cond breaking down after heating up also you may want to keep a test light or voltmeter handy to check for full voltage going into the coil when this happens good luck and hope this helps
