Demon carburetor Free speech parts auctions.
Bid on used parts to help fight the frivolous lawsuit filed against us.
Click here for details.
Parts currently up for auction: Don Garlits engine emblem, Demon carburetor, aluminum Hemi head, 1947 Chevy engine + suspension + parts, '30-'31 Ford headlights, '33-'34 Ford window regulator, "Power Rods" billet air cleaner top.
Mopar performance heads
Hotrodders Bulletin Board > Tech Help > Electrical
  #1
Old 07-26-2003, 06:08 AM
green66 green66 is offline
Coil Failure after heat up
This can't be a new problem, as some old guy walking by the car the other day told me about it while I was trying to get it started.
I have a 39 Ford with it's original Flat head. the car starts and runs great, until it heats up, then I lose spark. Is this coil failure? and what does everybody else do about it?
Old 07-27-2003, 09:36 AM
72 gmc 72 gmc is offline
New Member
re: Coil Failure after heat up
the coil would be suspect in this case but if you still have the original ignition setup ie points and condensor i would be more suspicious of the cond breaking down after heating up also you may want to keep a test light or voltmeter handy to check for full voltage going into the coil when this happens good luck and hope this helps
Old 07-27-2003, 02:05 PM
Kevin45's Avatar
Kevin45 Kevin45 is online now
Just one of the guys
yep. sounds right. either the coil or a condensor can do that. simple cure...replace with new.
kevin
Reply Back to top
Search this Thread:
Advanced Search
vB code is On
Forum Jump
