Should be able to run it horizontally, I can't see it affecting operation at all. The coil should be sealed well enough that oil doesn't seep out just 'cause it is on it's side or upside down.
I could see an advantage to mounting the coil inside the cab to avoid engine bay heat or moisture - and it can look cleaner too. |
You can mount an oil-filled coil in any position EXCEPT straight up. If the coil's mounted exactly vertical, the air bubble (that's always present in an oil-fillled coil) will be at the tower terminal and the heat build-up in that area will cause the coil to fail.
That's the reason all oil-filled stock coils are mounted at an angle. |
I have use them mounted horizontal, or vertical,with no trouble....
60's Chevrolet V8's had the coil mounted straight up from the factory. They still sell that style mounting bracket, for the original purists. I have only seen a couple of these go bad ever.
I work on a stock 1950 Buick straight 8, that has it mounted horizontal. When it stalls going up hill, and runs fine down hill, or on a flat section of road, it is time to replace the coil again. (4 so far in over 20 years) They all have leaked some oil out. 60's Fords had them mounted both ways, with few problems. All of the universal after-market coil brackets I have ever installed, have been horizontal, or vertical, not angled. Go figure. |
| Ignition system info................ | poncho62 | Electrical | 18 | 10-11-2008 10:10 PM |
| 1991 olds 88 3800 engine coil pack | fumplet | Engine | 28 | 07-19-2007 12:39 AM |
| How Does This Stuff Work? | docvette | Electrical | 3 | 06-18-2006 03:00 AM |
| Ignition Coil resistance Question | Old School Nut | Engine | 3 | 06-11-2005 03:36 PM |
| replaced coil still no spark off coil | jackfrost51 | Electrical | 11 | 05-12-2004 12:19 AM |
