-   -   coil over (http://www.hotrodders.com/forum/coil-over-229703.html)
kg44gasser 02-18-2013 11:08 AM
coil over
need some help. car weighs 3200,setting up laddaer bar coil over on rear. need to know what and how heavy of spring weights and shocks i need
OneMoreTime 02-18-2013 11:36 AM
What is needed is the weight on each axle and then pro shocks, speedway and others have charts to help pick the correct parts. If you are a serious racer then the adjustable units are in order as we adjust the shock valving and spring rates to get the best launch possible with your combo..
Sam
kg44gasser 02-18-2013 05:12 PM
coil over
thanks for info
