coil over
need some help. car weighs 3200,setting up laddaer bar coil over on rear. need to know what and how heavy of spring weights and shocks i need
What is needed is the weight on each axle and then pro shocks, speedway and others have charts to help pick the correct parts. If you are a serious racer then the adjustable units are in order as we adjust the shock valving and spring rates to get the best launch possible with your combo..
Sam
coil over
thanks for info
| MSD Coil and Coil Wire Question | Pre-Tuner | Engine | 4 | 10-06-2012 06:16 AM |
| Best coil to use? | STUDE55DOG | Electrical | 3 | 09-06-2009 03:40 PM |
| E-Coil vs. Oil Filled Coil | acr | Electrical | 2 | 03-03-2008 12:36 PM |
| DIS ignition, Visteon Corp. coil on plug / MSN coil per cylinder | Costa Rica | Electrical | 0 | 06-30-2005 02:13 PM |
| replaced coil still no spark off coil | jackfrost51 | Electrical | 11 | 05-12-2004 12:19 AM |
