Hot Rod Forum : Hotrodders Bulletin Board - View Single Post - Coil over concerns
Old 12-27-2012, 04:08 PM
tony@roadstershop tony@roadstershop is offline
As a general rule... most front coil over conversion kits that still utilize a "T" bar are engineered for the bar to sit on the top side of the lower control, not bolt from the underside up. That also being said, if there is a quality aftermarket arm designed to take a longer coil over in a double sheer mount... get it... you are doing yourself a huge favor ...
