Coil over concerns - Hot Rod Forum : Hotrodders Bulletin Board
Old 12-22-2012, 07:57 AM
Coil over concerns
Thinking about coilovers for my 69 chevelle concerned about if the two small bolts on the bottom shock mount cross bar are strong enough to support car weight any thoughts
Old 12-22-2012, 09:12 AM
NEW INTERIORS's Avatar
Set no limit's on yourself
If they sell it for your car,,Then I think they already know's it will work.. If they don't make a kit for your car.. Then no I wouldn't take that chance..
Old 12-22-2012, 09:18 AM
lakeroadster's Avatar
Hot Rods are Built, not Bought
Nope, the shock mounts were not designed to support the weight of the car. Huge difference between loading based on shock dampening vs. car weight.
Old 12-22-2012, 09:32 AM
thanks guys
Old 12-22-2012, 12:34 PM
123pugsy's Avatar
Last wiki edit: Metal shaping
Wiki Edits: 29
I'm running 5/8" dia, grade 8 bolts on my 41 Chrysler. Are you guys saying that the 4 bolts rated at something like 37,000 shear LBS each won't hold up a 4000# car?
Am I in trouble with my build? I can see the bushings needing replacement maybe, but I don't fore see a problem with bolt failure.
Old 12-22-2012, 01:01 PM
I would be more worried about where his shock mounted at the top hat then shearing a bolt... And I think the bolts he is talking about come in from the bottom... That would mean the weight of the car would be trying to pull the bolts straite out the threads.. Which is very hard to do.. Shearing a bolt and pulling one apart is two different things.. Bolt are more stronger then most people think..What I was trying to say was more like the metal above the shock then the way it bolts at the bottom of the arm..
These shocks are to replace the springs on a mustang II front end.. And the weight is on them bottom bolts..I don't think the weight of the cars would be the same.. Here the shock I'm talking about..
I think chev4u bolts are a little different then this one is.. I believe his are up and down not sideways..
Old 12-22-2012, 01:25 PM
123pugsy's Avatar
Wiki Edits: 29
Perhaps a call to the manufacturer to check , (is it tensile strength in that direction?) the specs.
Old 12-22-2012, 06:02 PM
Last journal entry: Albany Oregon Show
Shock mounts
Re-fab the bottom shock mount on your lower a arm and place the shock on the top of the plate instead of the bottom. I did this on my drag race Monza and it has worked good. I cut the lower shock plate out and welded a new plate in 1/4" lower and mounted the coil over shock on the top of the plate. Use 3/16 steel for the new plate.
QF
Old 12-27-2012, 03:08 PM
As a general rule... most front coil over conversion kits that still utilize a "T" bar are engineered for the bar to sit on the top side of the lower control, not bolt from the underside up. That also being said, if there is a quality aftermarket arm designed to take a longer coil over in a double sheer mount... get it... you are doing yourself a huge favor ...
Old 12-27-2012, 03:38 PM
123pugsy's Avatar
Wiki Edits: 29
You mean something like this?
Name:	IMG_2108 (Medium).jpg
The Following User Says Thank You to 123pugsy For This Useful Post:
chev4u (12-27-2012)
explosion concerns! atichargr Body - Exterior 36 07-16-2009 03:28 PM
Compression concerns. Siggy_Freud Engine 4 07-11-2006 10:06 AM
to whom it concerns midnytesun Introduce Yourself 1 09-30-2005 07:24 PM
Clearance concerns Rumblefrog Engine 2 05-01-2005 04:25 PM
