coil over question? - Hot Rod Forum : Hotrodders Bulletin Board
Old 11-18-2006, 08:48 PM
cheech beach's Avatar
Last journal entry: Cheech Beach
coil over question?
How can I tell the spring rating? I would like to order some stiffer coil overs, but I'm not sure what my current ones are.
Old 11-18-2006, 09:58 PM
Most sprngs have a small metal tag attached to a coil near one end of the spring with the spring rate stamped onto it. You might try looking for such a tag at the top or bottom of the sping.
John
Old 11-19-2006, 12:14 AM
2DOOR's Avatar
Fenders Should be Illegal
Spring Rate ID
You didn't mention the brand but if you happen to have Aldans the springs are identified by a painted color band on the end of the spring. Naturally that means you have to disassemble the coil from the shock to see it. I don't recall the colors but I'm fairly certain that a green band is a 180LB spring. There's black, red and some others. Check Aldan's website.
If they're not Aldans...sorry, can't help ya.
Old 11-19-2006, 12:44 AM
OneMoreTime's Avatar
Hotrodders.com moderator
Wiki Edits: 3
Springs are rated in lbs/inch..soooo if one puts a known weight on the spring to compress it one inch you now know the rate..They do make spring rate checkers as well if you like..
Sam
Old 11-21-2006, 12:29 PM
johnsongrass1's Avatar
Race it, Don't rice it!
Use a spring rate calulator I've posted on here before.
You need the wire diameter, the number of active coils, and the overall diameter of the spring center to center.
Old 11-22-2006, 01:28 PM
novajohnb's Avatar
It'll go, or it'll blow...
To get the actual rate of a spring is easy if you have a hydraulic press and a bathroom scale.
Place scale on press. Place spring on scale. Zero scale. Compress the spring an inch and read the scale. This gives you the spring rate (lbs/ inch.)
Be careful centering and lining up the spring so it doesn't fly out!
Works good for most low rate ~<300 lb/inch springs
Old 11-22-2006, 06:06 PM
BillyShope's Avatar
Philippines Cowboy
Last journal entry: THE TRACTION DYNO
I searched for your calculator, johnsongrass1, but couldn't find it. Here's the relationship I use:
rate = Gd^4/[8n(D-d)^3]
where G = 1.16E7 , "n" is the number of active coils, "D" is the outside diameter, and "d" is the wire diameter.
supercharger.... 73monte Engine 16 07-24-2010 11:27 AM
Push botton starter street rodder 1937 Electrical 4 03-17-2005 10:19 AM
Accel HEI Super coil question Jag Daddy Engine 3 05-31-2004 12:31 PM
Ignotion Set-ups Native Gearhead Engine 8 11-29-2003 02:20 PM
Hi All I just Joined, Questions Re:454 rebuild Gay-Shark Engine 8 11-29-2003 11:25 AM
