Coil Over Recommendation ?
Hello all - I'm new to the forum here and need some help ! .. I just installed an independant 4 corner Air-Ride Technogies system on my '52 Chevy small block pickup .. The Air-Ride works fine but the problem is I just don't like it (yep! it's brand new-never left the garage) .. I'm now in the market for a complete set of coil overs that I can do a direct swap/replacement (spring rate yet to be determined).. The rears are 15" installed length and the fronts are at 10 3/4" installed length.. Any help would be greatly appreciated as far as what company(s) .. offer a dependable component for a daily driver.
Chuck Darnell / Quincy Illinois cdarnell@insightbb.com 217-440-7422 Last edited by Chuck Darnell; 02-03-2008 at 07:56 PM. Reason: additional info |
Hi Chuck, welcome to the forum
I am assuming you have shockwaves, as those measurements you gave would be some ponderous tall bags Do you have a mustang II front suspension as well? You can take a look at speedway motors. They are selling QA1 shocks, which is not a bad shock for the money, and they have many lengths. A page with various lengths..listed by installed length. http://www.speedwaymotors.com/m/366_...rs-Mounts.html A page with some MII direct bolt ins.(if that's what you have) http://www.speedwaymotors.com/p/182,...Over-Kits.html A spiffy chart with some weights and general spring rate reccomendations. http://www.speedwaymotors.com/Produc...&displayId=182 http://www.speedwaymotors.com/Produc...&displayId=182 You might give air ride a call, tell them you want to calculate the necessary coil spring rate from the pressure you need to attain ride height with your bags/shockwaves.. You can also weigh the truck. then calculate the motion ratio and or shock angle to get a spring rate. . Hope this helps, Mikey
my signature lines...not really directed at anyone in particular.. BE different....ACT normal. No one is completely useless..They can always be used as a bad example Last edited by powerrodsmike; 02-03-2008 at 11:53 PM. |
Coil over Recommendation
Yes Mike - It is the Shockwave system .. I'll check with Speedway today and give them my installed height and see what they have to ffer.. Thanks -
Chuck |
| Ignition system info................ | poncho62 | Electrical | 18 | 10-11-2008 10:10 PM |
| 1991 olds 88 3800 engine coil pack | fumplet | Engine | 28 | 07-19-2007 12:39 AM |
| Help!! - 3.7 volts at coil pos.(no hair left..) | dabongo | Electrical | 1 | 09-07-2006 04:47 PM |
| How Does This Stuff Work? | docvette | Electrical | 3 | 06-18-2006 03:00 AM |
| Ignition Coil resistance Question | Old School Nut | Engine | 3 | 06-11-2005 03:36 PM |
