Coil Over Shock Adj....Correct Method - Hot Rod Forum : Hotrodders Bulletin Board
Old 08-02-2011, 12:30 PM
Ok...My 36 ford needs slight adj in the adjustable coil overs to rebalance the car...it has aldan shocks on it...I ordered a spanner wrench from summit for 30 bucks...its about 1/8 inch thick metal with a handle and adjustable....I jacked the rear of the car up, took the tire off and made my adjustment ...it was physically easy as the adjusting nut was all the way backed off to start and the spring loose....frontend was a different story...jacked the car up, took the wheel off and made my adjustment ...both sides were already about an inch adjusted before I started so there was plenty of compression on the spring...anyway, it was physically difficult to adjust...I moved it about 1/4 inch at most...its like compressing the spring from an already compressed position and with the lite duty tool I have it aint easy...anyway I have two questions...is there an easier way to do the frontend and should I be using a beefier tool...thanks..craig
Old 08-03-2011, 08:40 AM
coil over
i have the same thing,i pull the shock and put it in a vise and adjust it alot easier that way and it saves your knuckles
finding correct coil mmcarter17@aol.com Electrical 4 11-29-2008 02:47 PM
coil-over shock length jamesg Suspension - Brakes - Steering 1 04-05-2006 07:39 AM
coil over shock hotrod1935 Suspension - Brakes - Steering 5 07-21-2005 06:55 AM
Coil over Shock Selection jhenry Suspension - Brakes - Steering 1 03-15-2005 01:35 AM
Coil over shock selection jhenry Suspension - Brakes - Steering 1 02-03-2005 02:17 AM
