Coil-Over Spring Rate - Hot Rod Forum : Hotrodders Bulletin Board
Old 04-02-2009, 02:19 PM
J-Garden's Avatar
I'm about to purchase a 4 Link frame rail Kit from competition engineering. Just wondering what you guys thought the best set up would be for the spring rate. Going on a 71 Nova. Car will see the track ocassionaly(2-3 times a year) I plan on mounting the shocks behind the axle. I don't have the indiviual car scales to measure at each tire, and I'm still waiting on Dave Morgans book: Door Slammers that I just ordered. Thought I could get some helpful hints and anwsers in the meantime.
BB 454, 4 speed
1500 lbs at the rear
Total vehicle weight is 3520
Old 04-02-2009, 04:47 PM
ericnova72's Avatar
More for Less Racer
I would say 130 lbs springs.
Old 04-03-2009, 07:10 PM
406 bug's Avatar
9.82 @ 139mph
I would think 175 min. but call comp engineering or the manuf. you are getting the coil over form and they will be able to give you a rate. Other factor to consider is if you plan a straight up or angle on you coil over installation.
Old 04-03-2009, 09:14 PM
ericnova72's Avatar
More for Less Racer
The chart at Chassis Engineering puts you right in between 130 lbs and 150 lbs. If this is a drag car then I still say 130 lbs, if the street then maybe the 150's. We have 130's on the rear of a 4-linked 1967 El Camino at 3050lbs total car weight and they are borderline too stiff for drag use but the car does get street driven. Car runs in the 10's quarter mile on 315/65-15 MT Drag Radials.
Old 06-05-2009, 01:45 PM
J-Garden's Avatar
What width did you go with 24, 26 or 28?
Old 06-05-2009, 03:18 PM
ericnova72's Avatar
More for Less Racer
We built are own 2x3" tube frame in the rear because a kit frame was going to come up above the bed floor where it goes over the axle. Frame width was 32" outside to outside. The wider you can keep the frame (allowing for tire fit and sidewall flex) the more stable the car will be. I prefer to custom build my frame rails to get a more "personal" fit to the car, rather than a fits all kit. Not knocking the kits though, they are fine performance-wise.
We're running the MT Drag radial that matches up to a 30x 12.5" slick on a 10" wheel, with 5" backspace. Car was built with room between the rails and tubs to allow for a 12" rim with 6.5-7" backspace and a 31x 14.5 tire if we wanted to go bigger.
Get your wheels and tires first, so that you can set them under the car once you have cut away the wheelwells and trunk floor areas and measure off of them, DON'T rely on published tire size listings as they ARE NOT correct.
Good luck, measure 3+ times and cut once, and have fun . I enjoy building them almost as much as driving them!
Old 12-19-2009, 06:56 PM
J-Garden's Avatar
What would be a good Front Spring rate to go with?
Old 12-19-2009, 08:12 PM
ericnova72's Avatar
More for Less Racer
Factory style spring for the stock subframe or a coilover conversion??
Old 12-19-2009, 08:49 PM
J-Garden's Avatar
Coilover conversion
Old 12-19-2009, 08:57 PM
ericnova72's Avatar
More for Less Racer
I'd consult the company you plan to buy the coilovers from and tell them how you plan to use them - street/strip, drag, pro touring, cruising, etc.
Old 12-19-2009, 11:21 PM
68NovaSS's Avatar
Wiki Edits: 9
In my '68 Nova back half, 4-link car I run 150# springs on Alston QA's. It's a little rough on the street.
Horsepower is how fast you hit the wall.
Torque is how far you take the wall with you.
Midnight Sun Street Rod Association
Old 12-19-2009, 11:48 PM
J-Garden's Avatar
What do you run on the front?
Old 12-20-2009, 12:45 AM
68NovaSS's Avatar
Wiki Edits: 9
New big block coils, work good with the additional weight.
Cutting A Front Coil Spring leejoy Suspension - Brakes - Steering 21 03-31-2009 04:40 AM
Using Ring Style Coil Spring Spacer to Raise M-II Front End? acr Suspension - Brakes - Steering 2 04-03-2007 07:02 PM
front spring rate on 36 Buick rat rod henny496 Suspension - Brakes - Steering 3 01-07-2007 08:37 AM
coil overs to replace leaf spring? PairsNPaint Suspension - Brakes - Steering 3 12-03-2006 10:28 PM
Coil spring levelers? 5.0Towncar Suspension - Brakes - Steering 1 03-11-2003 07:24 AM
