Coil over springs - Hot Rod Forum : Hotrodders Bulletin Board
Old 05-22-2004, 06:42 PM
Coil over springs
I am putting coil over springs on the rear of a 28 Ford coupe. What dimensions do I need to have on hand to accurately order the springs?
Old 05-23-2004, 02:45 AM
BOBCRMAN@aol.com's Avatar
You will need to know the length and ID. that your shock is set up for. The length of shock travel, approx ride height and the sprung weight of the rear body. With these figures you will get the correct size and spring rate spring. Consult Carrara or Speedway
Old 05-23-2004, 04:35 PM
Thanks for the info - every bit helps.
Old 05-23-2004, 08:54 PM
302 Z28's Avatar
Your 28 is probab;y weighing in at about 2200 to 2500lbs. If your shocks have an adjustable collar a coil spring for this weight car is pretty much a standard item. Ride height can be set with the adjustable collar, or usually one of three shock mounting positions on the rear axle if so equiped.
Vince
