Coil Over for T-Bucket - Hot Rod Forum : Hotrodders Bulletin Board
Old 09-22-2005, 08:03 PM
I recently got a T project on the road that I purchased as a partially completed project. The chassis was built in 1989 and was never on the road.
The ride is VERY stiff. The rear coil overs have 160# springs. When I try to push down on the rear of the car I get no perceptible movement. I figure either the shocks are somehow locked up, do to age and non-use, or the spring rate is too high. According to Speedway's chart 140# may be better. Also the rebound adjustor on one side keeps turning. I hear a click so it isn't just a loose knob. The other side turns about 12 clicks and stops.
Any experience with either QA1 or Carrera coil overs?
Thanks,
Bill
Old 09-22-2005, 09:10 PM
Wiki Edits: 31
As T buckets are normally under 2,500 pounds, the suspension doesn't work properly because there isn't enough weight to bounce the suspension and due to ground clearence issues, it isn't a good idea for super soft suspensions. This is true to all traditional style repro parts buckets from '23-'25 and in some cases '19 cause CCR makes a '19 Bucket body.
Old 09-22-2005, 09:15 PM
OneMoreTime's Avatar
Hotrodders.com moderator
Wiki Edits: 3
You may need to drop down to a set of 90# springs on that car..does not take all that much to hold one of those up..As long as it does not bottom out. (sufficient spring travel) should be fine..i set my bump stops so the car does not scrape at full bottomed out springs..
Hope this helps a bit..Just maybe you can find someone in the neighborhood that stocks springs and will swap with you so you do not wind up with a whole box of springs..
the shock adjuster should be working..hope you do not have a bad one..
OMT
Old 09-23-2005, 07:38 AM
cboy's Avatar
Last journal entry: Finished
Bill,
Yes, those adjustment knobs CAN be turned to far. When I put QA1's on my pickup the instructions said NEVER turn the adjustment knob beyond the 12th click or it could severely damage the shock. The obvious question to me is, why in the heck would the mfr. allow the knob to be turned beyond the 12th click if it could damage the product. Whatever their thinking is, I'd turn both sides back to 1 (which IS a solid stop) and then adjust from there to get the best rebound you can...always keeping count of where you are at to prevent going beyond that final click. Hopefully in the short time you've had it on the road you haven't done any permanent damage.
Dewey
Always learning...and sharing what I've learned.
Old 09-23-2005, 07:51 AM
T-bucket23's Avatar
Wiki Edits: 26
Thanks,
Bill
I have a t-bucket and have ridden in several. They ride hard due to lack of weight. There is virtually no weight in the back except you and the gas tank. I would be interested to see if softer springs make a difference but again I have never ridden in one that doesnt ride like a buck board
If you change them please let me know if it makes a difference.
Thanks
Old 09-23-2005, 06:01 PM
BillyShope's Avatar
Philippines Cowboy
Last journal entry: THE TRACTION DYNO
See my post toward the bottom of the second page of "I have a crazy idea" in the General Rodding Tech section. You can have as soft a ride as you like. Just be certain that there's enough difference between "free" and "solid" lengths (on the spring) that it doesn't bottom out and you still have room for jounce travel.
Ignition system info................ poncho62 Electrical 18 10-11-2008 11:10 PM
Ignition Coil resistance Question Old School Nut Engine 3 06-11-2005 04:36 PM
Push botton starter street rodder 1937 Electrical 4 03-17-2005 10:19 AM
replaced coil still no spark off coil jackfrost51 Electrical 11 05-12-2004 01:19 AM
No Spark at Coil/ 350 SBC 1966impala Electrical 4 10-01-2003 01:07 PM
