Coil Overs or 2"drop springs with coil Over Shocks only. - Hot Rod Forum : Hotrodders Bulletin Board
Old 02-21-2013, 01:06 PM
I have a 1955 BelAir 2 door sedan, 350 with a 4 speed. I read somewhere that you could use stock 2" drop springs with a coilover type shock and it would work great, I have also been told that if you buy a coilover shock and spring dont get the small block ones get the ones for a big block because they will hold car up better.
I have a 350 with 4 speed, just installed 500 CPP box, Tilt, Ididit, all new front end rebuild kit with 2 inch drop springs, my headers are Hooker Competition full length and they hang a little low, am not useing any type of drop spindals. I need to install some type of shock and also would like to add a stablizer bar front and back useing stock Control Arms with 2 inch offset contol Arm Cross Shafts. Any information will be appreciated.
Leroy
Old 02-25-2013, 08:15 PM
I got mine from R&C for my Falcon you can adjust them up to 2" just by loosing two bolts they slide up and down pretty cool but the bolts can be hard to get to
Old 02-26-2013, 09:31 AM
Leroys 55 coil overs
Thanks, and I will check them out.
Coil over springs and shocks Tim34FSD Suspension - Brakes - Steering 2 12-02-2008 08:38 AM
Coil over springs and shocks Tim34FSD Suspension - Brakes - Steering 0 11-26-2008 03:45 PM
Model T "Coil Over" Rear Shocks Help Needed Bud's 27 T Touring Suspension - Brakes - Steering 12 09-05-2006 05:48 PM
leaf springs and coil overs jhenry Suspension - Brakes - Steering 2 11-25-2004 06:45 AM
Converting coil springs to leaf on a 9" BillyBob1950 Transmission - Rearend 9 04-25-2003 05:27 PM
