Coil position - Hot Rod Forum : Hotrodders Bulletin Board
Old 01-30-2011, 01:35 PM
Coil position
Is it true that a coil should not be mounted vertically with the wires on top?
Seems to me someone told me that one time (something about an air bubble)?????
Old 01-30-2011, 01:38 PM
vicrod's Avatar
life is a ride
Last journal entry: 2014
Electrically, it make no difference what position its mounted in.
vicrod
Old 01-30-2011, 01:58 PM
eloc431962's Avatar
Evil Wicked Mean And Nasty
Wiki Edits: 37
The only thing that i know of that would make any difference is if it's oil filled or gel filled. JMO And IIRC this only matters if you are mounting it on it's side. JMO
Cole
Old 01-30-2011, 03:31 PM
poncho62's Avatar
Wiki Edits: 5
Chevy v8s mounted them vertically from 55-74....and the worked just fine
Old 01-30-2011, 04:25 PM
The Chevy's were on a little slant. that's what the guy told me that there could be an air bubble that would float to the top of the oil and then bad connection????
Old 01-30-2011, 06:28 PM
ericnova72's Avatar
More for Less Racer
He is full of hot air. Only problems that arise from coil mounting is laying an oil filled coil on its side, the air bubble will cause the windings to overheat on the upper side of the windings. An oil filled coil has to be mounted vertically(or close to it) to keep the windings fully covered in oil for cooling.
Old 01-30-2011, 06:58 PM
eloc431962's Avatar
Wiki Edits: 37
Now that's what i'm talking about.
Cole
Old 01-30-2011, 07:04 PM
poncho62's Avatar
Wiki Edits: 5
Ford v8s used to have them on their sides on the intake....Were they not oil filled....or was that a problem with them?
Old 01-30-2011, 07:15 PM
T-bucket23's Avatar
Wiki Edits: 26
It is crap, you can mount it any way you want. If it is oil filled it is full so position does not matter. I can remenber seeing just about every orientation of factory mounted coils with the exception of upside down.
Chet
Old 01-30-2011, 11:45 PM
evolvo's Avatar
I think you should mount it with the coil wire pointing down so the electricity will fall out faster and your car will run better
Old 01-30-2011, 11:53 PM
ericnova72's Avatar
More for Less Racer
You can't do that...all the sparks will drain out overnight
I couldn't resist....
Old 01-30-2011, 11:55 PM
evolvo's Avatar
I thought that if you made sure the points where closed they would hold the sparks in! I hadn't thought about the resist
Old 01-31-2011, 06:34 AM
cobalt327's Avatar
WFO
Wiki Edits: 1616
Laying the coil down didn't seem to bother Ma:
Old 01-31-2011, 07:06 AM
Irelands child's Avatar
Then you consider the old pre '49 Ford coils mounted on the distributor, or might want to look at the HEI caps. In other words, what is up or down. Those fat old Mallory coils, the ones with the resistor around the secondary cover, I mounted mine on the firewall after I went to a 'Y' block in my '53 - and I never lost any sparks, even with my dual point distributor point wide open
Dave W
Irelands child
Old 01-31-2011, 07:35 AM
cobalt327's Avatar
WFO
Wiki Edits: 1616
If you're not convinced, you can switch to an "E-core" type coil. It doesn't have an oil in the first place, so it certainly doesn't care how it's oriented.
hei dist position yragat Engine 6 08-04-2008 08:41 AM
coil hot and car runs in off position grnova Electrical 4 11-27-2005 06:12 PM
DIS ignition, Visteon Corp. coil on plug / MSN coil per cylinder Costa Rica Electrical 0 06-30-2005 03:13 PM
Do SBC and BBC mount in the same position? 70bird Engine 3 11-06-2004 08:16 PM
replaced coil still no spark off coil jackfrost51 Electrical 11 05-12-2004 01:19 AM
