Coil question - Hot Rod Forum : Hotrodders Bulletin Board
Old 02-09-2011, 08:24 PM
69Bowtie's Avatar
Coil question
I'm looking to buy a new coil for my 69 Camaro. The motor is a 327 out of a 65 Chevelle that has been bored .030 over. I've been looking at an Accel Super Stock canister coil but I'm not sure which one would be the best for my motor ( primary resistance, voltage, secondary resistance). Should I also buy the Accel Points Eliminator Replacement Module or would this coil perform just as well with my stock distributor?
Thanks
Old 02-10-2011, 01:58 AM
SSedan64's Avatar
Lose the Points Distributor and stay away from Accell parts.
Drop a problem free HEI in it>> http://cgi.ebay.com/ebaymotors/ws/eB...K%3AMEWAX%3AIT
HEI conversion Info/Diagram>> http://rmcavoy.freeshell.org/HEI.html or here http://www.oldengine.org/unfaq/hei.htm
Old 02-10-2011, 07:17 AM
cobalt327's Avatar
WFO
Wiki Edits: 1616
Thanks
If looking original is a concern, get an MSD coil, paint it satin black and set the points and go.
Also you could use a points replacement module like the Pertronix #1181 under the cap of your original distributor- IF it's in real good condition. Their Flamethrower coil looks a lot like an OEM coil.
But like SSedan64 said, the HEI is a real good replacement if you don't mind the look and your intake will clear it.
Old 02-10-2011, 07:30 AM
delawarebill's Avatar
coil
i've use both pertronix and mallory point elimator kits and both work fine.. but...u need to make sure u have a ballast resistor or the kit WILL fail... if memory serves me its gotta be 2ohms or a little higher. as far as i'm concerned if u went to aftermkt coil that can put out 50k volts.. the coil will use what it need to just the plug gap. if thats 20k volts u didn't need the extra power cause u don't use it...
Old 02-10-2011, 07:48 AM
cobalt327's Avatar
WFO
Wiki Edits: 1616
The original points system he has will have a resistor wire already in place, instead of a ballast resistor.
There are other Pertronix kits like the #1181LS which is easier to install- it doesn't require the distributor to be disassembled for shimming like the #1181 kit requires you to do.
The 1181LS does NOT use a ballast, BTW. But all of this is covered in the info from Pertronix.
HEI Coil Question MidnightFord Engine 33 07-21-2010 11:53 PM
coil over question? cheech beach Suspension - Brakes - Steering 6 11-22-2006 05:06 PM
Coil over Question Will's41 Suspension - Brakes - Steering 2 07-31-2003 08:07 AM
Coil question Mickey Spillane Electrical 3 06-12-2003 11:44 AM
coil question Brick Engine 1 05-12-2003 04:35 AM
