coil specs SB 350 - Hot Rod Forum : Hotrodders Bulletin Board
Old 01-11-2009, 07:31 PM
coil specs SB 350
I have a 1990 Suburban w/ a sb 350. I need the ohm specs so I can test it. Does anyone know them?
Old 01-24-2009, 01:13 AM
the low voltage side wil be under 10 ohms the hi voltage around 2000 ohms
coils seldom go bad my buddies model A has its origional coil
the coil failures generally involve carbon tracks or cracks on the high voltage terminal
you will probably get the same ohm reading on a bad coil
a better method of testing would be to put a spark plug on the hv terminal and touch 12v to the low voltage terminal if you get a spark its probably a good coil
most of these new cars have resistor "wires"
these are a piece of string rubbed with graphite
after a year or so tend to be a lot more than the approx 1000 ohm reading you get with new ones
the insulation over the wire also deteriorates
so at night in a dark place have a buddy turn it over while you look at the wires. if you see blue flashes on all the wires replace them.
when my Toyota has trouble starting on a rainy day I replace the ignition wires, fixes it every time, $15 every other year or so.
sbc 350 block specs uncle mikeys race ca Engine 0 03-26-2007 03:21 AM
350 sb just rebuilt and it will not turn at all acts like its seized up Hpbbster72 Engine 9 09-16-2004 05:57 PM
need stock 350 chevy specs to compare to newly purchased eng olds6665 Introduce Yourself 0 09-05-2004 01:04 PM
73 350 sb not a 76 need specs pjsplayhouse Hotrodding Basics 2 11-01-2003 09:57 AM
Turbo 350 torque specs jmi Transmission - Rearend 1 06-20-2002 03:17 PM
