Coil spring for 350 on a S10 - Hot Rod Forum : Hotrodders Bulletin Board
Old 02-28-2008, 02:29 PM
Hi guys, i expected to put a 350 small block chevy on a S10 frame for my 1950 GMC. The question is; Can i use the original S10 front coil spring or if i put a heavier one.Thanks for all.
Old 02-28-2008, 02:52 PM
You can keep the stock springs. They are stiffer then V8 monte carlos. It will just sit a bit lower.
Old 02-28-2008, 03:26 PM
life is a temporary assignment
You can use the original spring's,They work find.
Old 02-28-2008, 03:35 PM
runn141's Avatar
SB S10
the tires will bottom out, especially with drop spindles. it will sway even with a stock diameter swaybar. unless you are not gonna drive it like it has a smallblock then youll be fine. bigger coils from a 1 ton truck or aftermarket and a swarbar atleast 1 1/8 in diameter.
Old 02-28-2008, 06:16 PM
Lou's Avatar
Lou Lou is offline
Last journal entry: some more body shots
I've done a bunch of the V-8 S-10 swap. I've never had any trouble with the springs or drop spindles. I would use the headers from Sanderson they fit nice.
Old 02-29-2008, 11:29 AM
Thanks for all guys, i'm not a pro in this case and i'm gonna take your proposition. With a new pair of coil spring, i'm gonna be sure of it. Thanks again.
'65 chevy P/U drop spindles or coil spring change? dar130 Suspension - Brakes - Steering 6 02-02-2008 12:27 PM
coil spring stabilizers jackflash Suspension - Brakes - Steering 3 09-02-2006 01:55 PM
Spring rates for coil over shocks ken demer Suspension - Brakes - Steering 2 08-13-2006 06:27 PM
8.5" 10-bolt coil spring rear end Kieran Transmission - Rearend 3 04-28-2003 04:24 PM
Coil spring levelers? 5.0Towncar Suspension - Brakes - Steering 1 03-11-2003 08:24 AM
