Coil spring compressor - Page 2 - Hot Rod Forum : Hotrodders Bulletin Board
  #16 (permalink)
Old 06-06-2006, 03:38 PM
propaneburner's Avatar
Last journal entry: Artillery wheels
Completed my spring compressor
Between the bottom disc and the coil is in my situation the lower a arm.
This pic. shows the treathed rod, its 3/4 thick high strength stainless steel.
The nut with rounded side is a sliding one, then there are two bearings with discs, and at last a 1 1/4'' x 2.5'' spanner nut.
This is the disc that goes inside the coil (top) with a hex locking system and a slot to put it around the rod.
The discs are two plates of 5/16'' welded together (a smaller inside so it cant slide out of the coil.
Total thicknes of disc 5/8''
Well the compressor works very well, and gives some piece of mint.
Was a day of work well spent.
  #17 (permalink)
Old 06-06-2006, 05:40 PM
OneMoreTime's Avatar
Hotrodders.com moderator
Wiki Edits: 3
Thank You ..that is a really nice job..
Sam
  #18 (permalink)
Old 06-06-2006, 09:19 PM
powerrodsmike's Avatar
Wiki Edits: 161
I think you need to send me that tool ....for "testing"
Just Kidding.
Super nice job! I like the thrust bearings.
Mikey
BE different....ACT normal.
air lines CARGUY Garage - Tools 96 11-16-2006 05:11 PM
HELP….HELP info on Moog coil spring, Im running iut of time 406chevelle Suspension - Brakes - Steering 7 04-25-2004 10:39 AM
info on Moog coil spring 406chevelle Suspension - Brakes - Steering 0 04-22-2004 10:26 AM
Coil Spring Movement Dave E Shank Suspension - Brakes - Steering 9 03-26-2004 08:36 AM
front end popping maddmaxx Suspension - Brakes - Steering 4 11-15-2003 09:24 PM
