Coil spring "extenders", "spacers", etc. - Hot Rod Forum : Hotrodders Bulletin Board
Old 01-17-2011, 09:45 PM
Hi guys, I was wondering if any one has experience using any of those various name products that suppose to lift up your front-end around 2"? I have a heavy 460 in my '78 Fairmont with a C6 with '88 Mustang LX 5.0 springs. Thanks.
Old 01-17-2011, 10:29 PM
johnsongrass1's Avatar
Race it, Don't rice it!
Why not buy longer springs in the right rates? the price is very close to those things from what I've seen in local parts houses.
Old 01-18-2011, 07:07 AM
Prices I've seen are about $6.00 to $20.00 for spacers or whatever they like to call them and $74.00 to $150 or so for springs. Also, if I get enough money, I may sell the 460/C6 and put in a 351; though I would like to see how it looks and if the raised front end actually lowers my et. Also, no idea what spring rates would be enough if I did get them eventually.
Old 01-18-2011, 12:17 PM
eloc431962's Avatar
Evil Wicked Mean And Nasty
Wiki Edits: 37
Spacers will work i'm not real fond of them but have used them before.
But springs would be the way to go if you want the best ride out of it .JMO
Do you drive this car everyday or just drag car only ?
Cole
Old 01-18-2011, 01:39 PM
001mustang's Avatar
Sticks
Seems to be a correlation between distance to city and spring spacer use.
Old 01-18-2011, 01:46 PM
eloc431962's Avatar
Wiki Edits: 37
Yeah sticks
Cole
ericnova72's Avatar
More for Less Racer
I don't see that raising the front end will help the ET. Most cars need as much front suspension travel as possible to enhance weight transfer and to prevent the front suspension from topping out too soon at the launch, before the car has firmly planted the rear tire. If you raise the front it will top out sooner and pull the weight back off the rear tires. This is why you see most drag cars so low on the front.
Old 01-18-2011, 01:48 PM
eloc431962's Avatar
Wiki Edits: 37
Dang i missed the "ET" part.
Cole
Old 01-18-2011, 09:33 PM
Cole
Neither, actually. I drive it mostly on streets and some highways in the good weather from late April/early May until late November/early December. I take it to the drag a couple of times a year. Do the spacers make it ride a little firmer or alot firmer, or somewhere in between?
Old 01-18-2011, 09:58 PM
001mustang's Avatar
I have driven a 5.0 sbf F150 w/ spring spacers in the front and it seemed to ride and handle like OEM. But, I'm not exactly the princess on the pea.
Old 01-18-2011, 11:36 PM
ericnova72's Avatar
More for Less Racer
A spacer won't change ride quality at all, all it does is raise the front of the car, the spring rate is still the same.
Old 01-19-2011, 07:52 AM
Ok, thanks.
Old 01-19-2011, 07:54 AM
Hmm, the plot thickens! Do you think raising the front 2" will give better traction when flooring it on the street?
Old 01-19-2011, 01:42 PM
ericnova72's Avatar
More for Less Racer
Nope, ...there is a reason no one build a nose high car(like the 60's gassers) anymore, they learned they were thinking about weight transfer the wrong way. All raising the nose does is take potential weight transfer away. Transfer only happens while the front end is rising, once it tops out transfer stops. If you start with the nose higher it is going to top out sooner limiting the amount of time transfer is helping to plant the tires.
What does your rear suspension consist of??
Old 01-19-2011, 03:34 PM
eloc431962's Avatar
Wiki Edits: 37
I have them in my camaro and they seem to do ok. But how does it keep the same spring rate with a more or less a block in between the springs spreading the spring out to lift it ?
Cole
Strange thing happening with my clear "solvent pop"/"fish eyes" ? myfamiliacc Body - Exterior 35 02-16-2013 07:18 PM
Covering stock "plastic" door panels with "vinyl" csilva84 Interior 1 10-05-2007 06:30 PM
wiki pages: "How to rebuild an engine", "Window removal/installation" Jon Hotrodders' Lounge 0 07-11-2006 12:44 PM
Hey croz look """"IMPORTS SUCK""" 78 monte Hotrodders' Lounge 14 08-30-2002 01:13 PM
