Coil Spring Hitting Frame? - Hot Rod Forum : Hotrodders Bulletin Board
Old 09-22-2009, 01:41 PM
I just bought a 71 Chevelle. While moving the car around my yard I heard a banging/grinding noise from front end. It turns out that the passenger side coil spring is rubbing against the hole in the frame. It's like the spring isn't centered. Is it possible the spring was installed upside down? If not what else could cause this? The bottom of the spring appears to be seated properly, but I can't see the top. There doesn't appear to be any damage to the frame either. Most of the front end parts look new, so I thought that maybe someone just put the spring back in wrong when reassembling everything. Any help is greatly appreciated.
Old 09-22-2009, 02:27 PM
willys36@aol.com's Avatar
Wiki Edits: 21
Can't imagine what you are saying. Can you post a picture? Does the car have full weight (front clip, engine and tranny, etc.) on the front end? If not the springs are probably extended and they will do strange things in that condition. Not intended to operate that way so not to worry, will go back to proper shape when car is done. If that's not it, something is brorken or bent and needs to be addressed.
Old 09-22-2009, 03:52 PM
Thanks for getting back to me. I don't have a picture, but I'll try to explain it better. The spring is sitting in the lower control arm as it should. There is a hole in the frame that allows the spring to go through and sit against the top of the frame. The spring is so far to one side that it is rubbing against that frame hole. The car is completely assembled and other than the new front end parts appears to be a completely original 78k mile car. Hope this helps. Thanks
Old 09-22-2009, 07:34 PM
The top end of the spring is not properly seated in the spring pocket. The upper spring pocket on the A-body cars has a cylinder that the spring is supposed to fit over to keep it centered. This installation is blind and I have had the spring slip off the cylinder and move to one side of the seat as you describe.
Old 09-22-2009, 07:43 PM
poncho62's Avatar
Wiki Edits: 5
Or...the spring is broken
Old 09-23-2009, 07:55 AM
Wiki Edits: 21
Regardless, something isn't right under there so I'm afraid you are facing a spring compressor and popping that spindle and looking.
Coil spring mount and selection questions iceman36 Suspension - Brakes - Steering 8 05-20-2009 02:20 PM
Front Coil Spring Removal 189fmc Suspension - Brakes - Steering 1 09-19-2008 10:59 PM
Tubbing rear with original frame rails? chieftain Suspension - Brakes - Steering 1 04-25-2007 09:02 PM
coil spring compressor(pic) montea Suspension - Brakes - Steering 3 04-10-2007 12:47 AM
Federal-Mogul #8542 Coil Spring Rate Bill Ford Suspension - Brakes - Steering 0 04-09-2003 07:36 PM
