Coil Spring holdup - Hot Rod Forum : Hotrodders Bulletin Board
Old 05-12-2009, 07:38 PM
iceman36's Avatar
Coil Spring holdup
Coil Spring holdup
Maybe some in here can answer this question since the two companies I emailed havenít. For a Coil Spring that is 5Ē OD what would be the ID? I know it depends on the coils wire diameter. But there has to be some way to design the mounting points if you donít know the exact vehicle weight to select the exact in/lb spring needed. Or is it just an estimated guess by subtracting twice the guestís wire width from the outside diameter?
Mike
Old 05-15-2009, 06:40 PM
It makes sense to me that the OD minus 2x the wire diameter would be the ID.
Give me a minute to check on a coil spring I've got.
Edit -- Yep. Take the OD and subtract 2x the wire diameter.
Old 05-16-2009, 11:47 AM
Most spring mounts for 5" springs are 3 3/4" diameter. It does not have to be a tight fit.
Cutting A Front Coil Spring leejoy Suspension - Brakes - Steering 21 03-31-2009 05:40 AM
'65 chevy P/U drop spindles or coil spring change? dar130 Suspension - Brakes - Steering 6 02-02-2008 12:27 PM
coil spring bushing on 68 stang elcaminodragster Suspension - Brakes - Steering 4 07-03-2007 11:57 PM
Coil Spring Movement Dave E Shank Suspension - Brakes - Steering 9 03-26-2004 08:36 AM
coil spring install on camaro subframe kid Suspension - Brakes - Steering 3 08-25-2003 07:26 PM
