coil spring install on camaro subframe
I have a 56 chevy truck with a 79 camaro subframe on it. How do I put the coil springs on? I rented a compressor from the auto parts store and it dont work very well it keeps sliping off and thats a little scary to me. The truck is stripped down to the bare frame so a floor jack just lifts the whole thing up. Any suggestions will be appricated. Also does it matter what end is the top or bottom? One end has a little mark or notch on it. Please help me save my teeth. Thanks
The chain trick is a good safety plan. If you had tie downs in the floor it would be easy. Or set an old engine in place , or get a few beer gut buddies to get on the frame.
A trick I have used works pretty good is have your jack under the lower a arm, chain the upper a arm to the jack, then raise the lower a arm with the jack, this should hold the upper a arm in place. Good Luck. Troy |
Thanks for the info. The chain around the jack trick looks like it will work pretty good. Just gotta get me somemore chain. Maby this weekend.
![]() Thanks for the info. The chain around the jack trick looks like it will work pretty good. Just gotta get me somemore chain. Maby this weekend.
