Coil Spring Measurements - Hot Rod Forum : Hotrodders Bulletin Board
Old 11-25-2005, 03:02 PM
rbfpezcore's Avatar
Not fast, but loud as hell
I have a 62 Cadillac fleetwood that I want to change the suspension on. Its real loose and i get a little too much roll. I would like to stiffen it up a little and get it an inch or two off the ground. I scrape my pipes just about everytime i take it out because it is so low. I was wondering if anyone knew how I could find measurements for my springs without taking them off now. I would much rather take the springs off and replace them all at once. Also, if I can find the measurements, would modern springs work just the same as opposed to special ordering $400 in springs? thanks in advance
Old 11-25-2005, 05:44 PM
BillyShope's Avatar
Philippines Cowboy
Last journal entry: THE TRACTION DYNO
Sounds like a previous owner has really screwed that car up! The last thing a '62 Cad should be accused of is being loose. Have the springs been shortened? Is the front swaybar still connected?
The obvious solution would be a trip to your friendly Cadillac dealer for a purchase of stock springs. Don't know how "friendly" the prices would be, but that would certainly get the car up in the air and give you more than enough plow in the corners.
Old 11-26-2005, 04:15 PM
rbfpezcore's Avatar
The car is completely stock, nothing has been changed. But i guess because it is so old the springs have really loosened up. I tried the local caddy dealer and they had nothing. I checked with another place and they had nothing. But i got a few more to check.
Old 11-26-2005, 04:53 PM
OneMoreTime's Avatar
Hotrodders.com moderator
Wiki Edits: 3
Try stockcarproducts.com for one..Found these guys as well http://www.kanter.com/p50-cs.html
they may be able to help you..
OMT
Old 11-26-2005, 05:52 PM
xntrik's Avatar
Save a horse, Ride a Cowboy.
Loose means two different things to two different people.
Billy is a chassis engineer and makes sports/road race cars handle!!!!!..... I think that Billy is talking about "loose" handling (oversteer) where the rear end wants to spin out on corners, that is why he came up with "more than enough plow" comment (the opposite of loose/= understeer = tight= push=plow).
Old 11-26-2005, 06:55 PM
rbfpezcore's Avatar
Oh, my mistake. I was referring to the ride, not the steering.
Coil Spring Spacer Bill Ford Suspension - Brakes - Steering 4 06-06-2004 10:24 PM
If I cut a coil spring Bluepen Suspension - Brakes - Steering 2 06-01-2004 07:06 AM
HELP….HELP info on Moog coil spring, Im running iut of time 406chevelle Suspension - Brakes - Steering 7 04-25-2004 10:39 AM
info on Moog coil spring 406chevelle Suspension - Brakes - Steering 0 04-22-2004 10:26 AM
Coil Spring Movement Dave E Shank Suspension - Brakes - Steering 9 03-26-2004 08:36 AM
