coil spring rates #'s
http://www.classiccarsprings.com/springrates.html okay, enough is enough. need to decide what frikken coil springs you need and want to get the whole poop, and nothin but the poop on diameter, rates, et cet terr-AAAHHH? here! take a hit on this: http://www.classiccarsprings.com/springrates.html
ok..a bit aobut this
What does your ride weigh on the front axle and on the rear axle??
That is the first thing that is needed to be known...Then go down the chart..Find the ones that support the proposed load..then check to see that the spring ends are like the ones on the spring you have removed.. Check free height which is the height of the spring when it is out of the car..and pick one of a similar free height..and check the installed height so you get a spring of the proper installed height..that is if the ride height is now where you want it to be.. what kind of ends do the current springs have..?? Spring rate refers to the amount of weight it takea to compress a spring 1" Inside dia of the spring should be clear..what do the old ones measure?? Bar dia is the dia of the wire used to make the spring..thicker wire the spring is stiffer.. Now if all else fails..weigh the front end and call the guys and tell them you have a car that weighs so much and is one of these..and get a recommendation.. OMT |
yeah, this table tells you all that stuff. it gets worse without it asking people what to run. i would just go by the table and forget it, but you have to know what your car came with, then take others advice into consideration, with a grain of salt. if they have a 79 with the big plastic bumpers instead of a 72's tiny little bumper, if they have fiberglass parts, aluminum heads, a/c, automatic etc etc, it gets to be a real PITA!!!!
my 72 camaro came with (and all those numbers above are MOOG NUMBERS BTW!) spring #5278, i was told by a bunch to get the 5610's. i was told by the classic car spring rep to get the 5600, and by others to get the t/a's WS-6 springs. it all looked good when you check all the parameters you mention, except for the load they are supposed to carry. i figured i wanted to get as close to stock as i could, but be under it to account for the aluminum intake and headers. so i went with the 5642 instead of the others. the pontiac stuff, esp. the later years, is for a much heavier car, although the stockers on my camaro are for 2080lbs. i want to lower my car about an inch. i think that this will put me where i want to be. i can't tell you how much time i have wasted on this one part. snafu!!! |
| HELP….HELP info on Moog coil spring, Im running iut of time | 406chevelle | Suspension - Brakes - Steering | 7 | 04-25-2004 09:39 AM |
| info on Moog coil spring | 406chevelle | Suspension - Brakes - Steering | 0 | 04-22-2004 09:26 AM |
| Extra-High-Lift coil spring for 72 chevelle | 406chevelle | Suspension - Brakes - Steering | 5 | 04-03-2004 05:00 AM |
| Coil Spring Movement | Dave E Shank | Suspension - Brakes - Steering | 9 | 03-26-2004 07:36 AM |
| rear coil over spring rates | stea | Suspension - Brakes - Steering | 8 | 03-06-2004 06:01 PM |
