Hot Rod Forum : Hotrodders Bulletin Board - View Single Post - Coil spring rear suspension for 52 chevy coupe
Old 02-24-2009, 09:34 PM
matt167 matt167 is offline
Wiki Edits: 31
if you still have the torque tube, you need to change that first.... the rear suspension is actully supported by the torque tube, so anything other than the factory leafs with the torque tube, won't work.
